P38 Range Rover advice
Started by Elite Pete, 27 December 2013, 16:24:35
Quote from: ex taxi al on 03 January 2014, 12:45:03
Quote from: aaronjb on 03 January 2014, 12:07:22
This is a dangerous thread .. it got me looking at Range Rovers and then latterly Defenders on fleabay.. ;D
At which point I hope you realised that actually the Omega isn't quite as ruinous to run as you first thought ;D
;D ;D Pretty much! Amy's Dad has a (relatively nice) Defender and I have a soft spot for them - but I probably wouldn't buy one unless (like him) I knew a specialist who did work ridiculously cheaply..
Though I did see one that was originally a RAF Landy now sitting on a galv. chassis with what must have been a brand new body too - looked quite nice, if a little bit like Triggers broom! ;D
henryd
Quote from: Marks DTM Calib on 03 January 2014, 12:47:16
Aaaaaggggghhhhhhhh.......... ::)
One life,live it ;D,you know it makes sense ;D ;D
other rides
the alarming man
Quote from: Marks DTM Calib on 02 January 2014, 08:12:03
And I bet I could prove the pair of you wrong, there will be at least one cylinder down on power by about 30%....and cam timing will be out.
Its an inherent design fault with them on the cams, followers and chain drive.
As they are an 8 they mask the issues very well ut they will be far from thier best (not that they ever were brilliant)
trust me mine is firing on all eight equally .. i have the fuel bill to prove it!! :y
the alarming man
Quote from: aaronjb on 03 January 2014, 14:52:04
Defenders are hard work in the cold much better to sit on a heated leather seat :y
