Author Topic: rear wheel bearing - easier to change the whole arm?  (Read 5751 times)
chrisgixer
Re: rear wheel bearing - easier to change the whole arm?
« Reply #15 on: 31 December 2013, 19:21:37 »
Any play in the wheel/bearing?
No, none either side.
Not the wheel bearing then. :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #16 on: 01 January 2014, 07:19:18 »
You are quite right. Thanks for being firm with me. I was convinced it was wheel bearing, because it was a noise I have never heard before on a car, and which fitted the description of a failing bearing - road speed dependent, independent of power, cornering, braking, and beginning as a low moan, slowly rising to a drone with increasing speed. If not a bearing, what is it? I now think it must be the n/s rear brake, either a rusty disc rubbing the back plate, or something inside the drum brake. Today I shall investigate, and report back.
« Reply #17 on: 01 January 2014, 10:41:24 »
Near side always suffers when the weather is crap because of all the shite on the side of the road and in the puddles :-\
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #18 on: 02 January 2014, 06:24:46 »
I've replaced a few and some have been completely playless, only made horrendous noise when driving. One good way to spot rear wheel bearing fault is to drive the car and turn left and right, sound should change if bearing is on its way
« Reply #19 on: 02 January 2014, 10:10:01 »
Yep, I can only recall one where thee was actualy any play that could be felt (no surprise as they are a twin race bearing)
terry paget
    • 3 Astras 2 Vectra
« Reply #20 on: 11 January 2014, 10:43:27 »
Thanks. I performed thi test
Thanks. I performed this test yesterday. Bad news. Turning to the left the noise ceases. Noise seems to come from rear left hand wheel.
I stripped the n/s hand brake last week. There seemed to wear between the brake drum and backplate at the top half, as if rubbing had taken place. I changed the brake drum, but nothing changed. Bother. Job to be done, I fear. I am inclined to change the clutch in the 3.2 first. It sounds easier.
« Reply #21 on: 11 January 2014, 11:10:24 »
Rear wheel bearing done by an extremely knowledgeable and help Mr Sassenach, who resides in Trowbridge, so not that far from you, took less than an hour !! He has some self-manufactured items which made the job so easy it was gob-smacking !!
I would suggest a PM to him, along with a grovel, and an offer of beer tokens ....you never know your luck unless you ask ....  :)
(If the other one on mine EVER needs doing I will be groveling long and hard !!  )  :)  :)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #22 on: 11 January 2014, 13:17:18 »
But sadly inactive since September! :(
terry paget
    • 3 Astras 2 Vectra
« Reply #23 on: 11 January 2014, 14:54:42 »
Thanks. That's excellent news. He offered to help me last year on an ABS and front hub matter. Trowbridge is about 12 miles away. When I approach the job I will make contact.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #24 on: 11 January 2014, 17:32:59 »
He is still about though if it's the same sassanach that's on landyzone.
other rides
