Author Topic: Oh no . .CS Help  (Read 5644 times)
Big_Al
Oh no . .CS Help
« on: 05 January 2014, 11:32:58 »
hi guys
              right this Neffin' omega is getting right up my nose now  >:( >:( >:( >:( >:(
This is a new thread carrying on from what was breakdown diagnosis
Oofers general opinion was crank sensor  as was getting 0335  sometimes after  car was cutting out.
Car cut out last week outside house so ordred new genuine bosch CS.
Yesterday wanted to get car up on ramps & it started 1st time but then cut out before I could get it on the ramps  :(
Started raining really heavy so left it until this morning ::)
This morning it would not start so just jacked up N/S  replaced C/S & rerouted cable as shown  :y
Would not start with the new CS fitted  >:( >:( >:( >:( >:(
Ok so thought I would do pedal trick but this would not work  . . . TC light was staying on which normally goes off on a pedal  trick
code read  &  the spanner light would not flash at all just lit up all the time  .
Tried several times but no good  >:( >:( >:(
I  was thinking that  maybe it is an ECU problem like Toledodude Paul had last year ,as TC light came on before a recent breakdown .
So opened up ECU box & checked all connectors .They seemed all ok but released & re fitted to make sure .
Tried starting  . . . .Hey presto  . . .Magic   on the button   it starts .    Have started it 20 times now & gone for a short drive
All OK.      Pedal trick will now work  showing 2 codes ,will have to re check the first one  but second is 0335
Will now clear codes  & see what happens .
Would you think it seems logical that a dodgy ECU connection will cause this problem I have had  and not the CS after all .
CS was previously changed 35k ago
Any thoughts & advice  on this  . . before the car gets chucked  ::) ::) ::)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: Oh no . .CS Help
« Reply #1 on: 05 January 2014, 15:54:10 »
The sensor just originates the pulses.  They've still got to get to the ECU.
CS is such a common problem with these (mine was temperature sensitive) that everyone immediately points there.  There's no reason why you shouldn't be the first to have a connection problem elsewhere.  The error-detection will not be able to tell the difference - just that pulses are missing.
Only time (and your patience if you have any left) ;D will prove your point.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Big_Al
« Reply #2 on: 05 January 2014, 16:52:31 »
Have been out & reconnected the old crank sensor . . ..  car starts first time . . . tried for several starts  . . all good
replaced again with new one  & all still good  . . car starts A1
Cleared codes this morning after getting car running with new sensor fitted . Pedal trick is now working & no codes showing
Only time will tell if it was a loose ECU connection i suppose.  The fact that the pedal trick only won't work when the car will
not start, points to the ECU I would say . As soon as car is running & starting ok ,pedal trick will work  :-\ :-\
Has anyone ever had the "pedal trick" fail to work & not give the code flashes with the spanner light, like this did when car does not
want to start . Just to confirm  what has been occuring , car just cuts out & will then turn over as normal but will not fire . leave
for a while usually 30 mins or more & it will start.
Very frustrating this problem. :'( :'( . . . . . been looking at Volkwagen Phaetons  . . as getting fed up with this now :-* :-*
« Last Edit: 05 January 2014, 16:57:29 by Essex Big Al »
AndyStobbs
« Reply #3 on: 05 January 2014, 19:11:04 »
Is your car new enough to give freeze frame data? If you looked at it with a scan tool there maybe more useful info to be had.
Big_Al
« Reply #4 on: 05 January 2014, 19:18:28 »
'51 plate   2.6  MV6 . . . .but clueless with all that stuff . . . .   I'm 57 for gods sake  . . PC   IT    hopeless  at it  :-[ :-[ :-[ :-[ :-[
Can put fuel in & change oil  though  ;D ;D ;D ;D     :y :y :y :y
AndyStobbs
« Reply #5 on: 05 January 2014, 20:25:40 »
It will be then. When a fault code is set a snap shot of parameters at that point is taken. It includes rpm at that point. If you're getting crank sensor faults logged the rpm at which the fault occured may help you out.
« Last Edit: 05 January 2014, 20:27:51 by AndyStobbs »
« Reply #6 on: 05 January 2014, 20:26:33 »
As requested you have pm Al :y
chrisgixer
« Reply #7 on: 06 January 2014, 00:52:43 »
Only time I've had the pedal trick fail is when I left the drive by wire plug off the throttle body on the plenum, Dbw needs to function to see the accelerator pedal position obviously.
Ecu needs to see the cs signal. Cs is most common failure so you have no choice but to start there. Any pins corroded on the loom plug or ecu pins?
Fingers crossed you've sorted it anyway. :)
Big_Al
« Reply #8 on: 06 January 2014, 07:17:01 »
Ok thanks   ;). . . but will have to leave that to someone who understands how to do it  etc. :-[ :-[
Big_Al
« Reply #9 on: 06 January 2014, 07:20:55 »
Car is running fine  again at the moment , new CS is fitted, although test run with old one re installed, was good, but will check all ECU pins &  all loom connections .
It is looking like an "intermittant"  wiring connection breakdown now though :-\
« Last Edit: 06 January 2014, 07:22:27 by Essex Big Al »
Big_Al
« Reply #10 on: 07 January 2014, 19:07:22 »
40 mile trip today   & all  running luvverly. . .  .used electrical cleaner spray on engine ECU pins & main loom connections under
battery before I went  . . . . never missed a beat & no "spooky"  radio turning itself on etc.   All good so fingers crossed  ::) ::)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #11 on: 07 January 2014, 21:11:00 »
Maybe some water got somewhere nasty giving you problems, there has been a lot about Al :)
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Big_Al
« Reply #12 on: 07 January 2014, 21:13:30 »
quite possible Paul . . . . as said running good again now ;) ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #13 on: 07 January 2014, 21:18:00 »
These ageing omegas do test the patience! ;D
Keith ABS
  • Maldon Essex
« Reply #14 on: 08 January 2014, 19:38:22 »
  I had some very odd probs with running then not, not starting then it would after half an hour  with a MG Montego EFI. Turned out to be alternator on that
keith B
