Author Topic: Dash and headlights flickering at idle  (Read 4623 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« on: 05 January 2014, 15:01:46 »
Hi all,as said.Is this bad earth or alternator.TIA Dean :y
chrisgixer
Re: Dash and headlights flickering at idle
« Reply #1 on: 05 January 2014, 15:06:56 »
Starter for 10
Flat battery. But ignore me I'm shite with electrics.
moggy
  • hartlepool
« Reply #2 on: 05 January 2014, 15:22:38 »
Starter for 10
Hi Chris,fully charged battery last night,went to asda today.Sitting at traffic lights dash lights flickering,how much for a new alternator.Dean
« Reply #3 on: 05 January 2014, 15:34:59 »
Starter for 10
Have alook at your existing alternator first  ;) http://www.omegaowners.com/forum/index.php?topic=90512.0
moggy
  • hartlepool
« Reply #4 on: 05 January 2014, 15:46:18 »
Starter for 10
Thanks andy,but i dont think i am up to takeing it off and inspecting.Would it be cheaper and easyer to just change it mate.Dean
« Reply #5 on: 05 January 2014, 15:52:05 »
Are your heated seats On?
I find they cause the dash lights to flicker as the element cycles on and off.
« Reply #6 on: 05 January 2014, 15:52:47 »
....Thanks andy,but i dont think i am up to takeing it off and inspecting.Would it be cheaper and easyer to just change it mate.Dean
I can't see thee being much difference in cost between a repair to your & A N Other ...... but do you know the 'new' one will be any better?  ;)  ;)
I'm sure that someone here will be able to fix you up with a known to be OK alternator for not much ..... but it'll still need fitting.  ;)
moggy
  • hartlepool
« Reply #7 on: 05 January 2014, 15:59:42 »
Hi Kevin,no mate just the heater blower on.And when i got home i turned it off but still had the flickering.dean :y
moggy
  • hartlepool
« Reply #8 on: 05 January 2014, 16:04:44 »
Well Andy,it looks like my best bet is to buy a brand new one.And get someone to fit it,at least it would be on thing eliminated. :y
« Reply #9 on: 05 January 2014, 16:32:43 »
The best thing to do would be some diagnosis first. It could well just be a loose connection. The crimps on the battery terminals are a favourite.
moggy
  • hartlepool
« Reply #10 on: 05 January 2014, 16:41:26 »
You may well be right Kevin.But i have tightened the crimps but they do look worn.What about earthing problems,or am i talking out of my bum. :y Dean
chrisgixer
« Reply #11 on: 05 January 2014, 16:43:16 »
...and check the earth strap?.... by the radiator drain, they can rot through sitting in water on the drip tray.
Kev has fine a very good diagnosis guide in maintenance for battery and alternator, with a meter.
Ime the 2.5 and 3.0 are quick to throw the warning light on if the alternator plays up. Its worth further investigation of the simple things like connections first. :)
moggy
  • hartlepool
« Reply #12 on: 05 January 2014, 17:01:59 »
Thanks for the reply chris,what warning light would show up for alternator,as none on at the moment.Also where is this earth strap you talk of mate. :y
chrisgixer
« Reply #13 on: 05 January 2014, 17:08:31 »
The alternator warning light on the dash.
As said, earth strap, is down by the the radiator coolant drain. You need to stand by the battery, then look up from under the bumper. You'll see a braided steal strap, it sometimes rots through.
moggy
  • hartlepool
« Reply #14 on: 05 January 2014, 17:45:28 »
Sorry mate i didn't know there was an alternator warning light,i have seen the braided strap.Will check tomorrow any other advice welcome.Dean
