Author Topic: Tyre profile...?  (Read 2841 times)
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Tyre profile...?
« on: 05 January 2014, 16:15:50 »
Hello folks, just a little advice needed please :)
What tyres would I need for 18" wheels for the Omega....?
TIA Matt
D.I.L.L.I.G.A.F...
chrisgixer
Re: Tyre profile...?
« Reply #1 on: 05 January 2014, 16:30:03 »
What's the width? 8j ?
...and ET number?
minifreek
  • Wigan
« Reply #2 on: 05 January 2014, 17:53:35 »
They're currently on my Vectra so ET49....? and running 215/35/18 tyres at the moment... I think they are 8J...? not 100% though...
D.I.L.L.I.G.A.F...
chrisgixer
« Reply #3 on: 05 January 2014, 18:02:14 »
Ah, no experience with that size, but be carefull vectra wheel don't foul the shock on omega. You need at least 10mm from the rim to shock body on omega with camber set to -1.10.
« Reply #4 on: 05 January 2014, 18:23:05 »
If the wheels are 8j, then the tyres you need are either 235/40/18 or 245/40/18 :y
Wheels ideally need an offset of ET 33 or ET 30... ET38 8J wheels fit, just. So you'll need suitable spacers/bolts to fit them to the Omega :y
To add, if the Omega is fitted with 225/55/16 tyres, if you should ideally fit 245/40/18s, as they have the same rolling radius :y
« Last Edit: 05 January 2014, 18:27:27 by ex taxi al »
minifreek
  • Wigan
« Reply #5 on: 05 January 2014, 18:53:59 »
Thanks for the answers folks, looks like I'll be either fitting bigger tyres and using spacers or selling the wheels on :(
I'll try them on the Omega when I get it Saturday and go from there...
The wheels that are in question are 18" BK299, I was hoping they would fit the Omega without problems.....
D.I.L.L.I.G.A.F...
AndyStobbs
« Reply #6 on: 05 January 2014, 19:06:35 »
The omega I bought to break had bk158 on it. They are 18 x 7.5 j and et40. Fitted with 235/40/18 there was no issue with them rubbing.
« Reply #7 on: 05 January 2014, 20:01:14 »
ET38s with 8J wheels have very little clearance... it stands to reason that narrower wheels can carry a higher offset without fouling ::)
In fact, with standard 16", 6.5J wheels which have an ET of 39, there is about an inch of clearance at the strut :y
AndyStobbs
« Reply #8 on: 05 January 2014, 20:06:39 »
As the O.P isn't certain his are 8j then my info could be useful should they turn out to be 7.5j.
« Reply #9 on: 05 January 2014, 20:16:24 »
See how you get on... If your original measurements are right, I doubt the fronts will fit, the rears might well fit physically, but cosmetically they will look wrong, and mechacally, the rear track will be out :-\
If you need spacers, then I would suggest 10-15mm, and bear in mind that you need to allow for suspension work... only leaving a couple of mm clearance at the strut, might not give enough room to adjust the camber as and when the lower arms/bushes need changing :y
