V6 Sports Mode volume II
Started by Webby the Bear, 09 January 2014, 19:06:13
SMD
There is definitely a noticeable difference in my 3.2
Webby, changing up at 4,000 RPM makes me think your kick down switch might not be working. Mine changes up at about 6500 on full chat, sport mode or not.
Quote from: Kevin Wood on 09 January 2014, 23:02:41
Or just generally light on throttle ;)  Agreed if "booted" should change up a gear around red line.
Webby the Bear
Thanks Kev.
Yep, definitely doesn't go as higher revs as in Sports mode. If the switch was nackered though would it kick down at all? it does kick down in both modes but as said changes up at 4k and red lines in sports mode.
Where does this switch live and is there a way of testing it? :)
RIP Paul Lovejoy
Key thing for the swicth is ensuring that there is very little slack in the throttle cable, the swicth is integrated into the throttle cable and sits by the scuttle on the driveers side of the engine bay
Webby the Bear
Quote from: Marks DTM Calib on 10 January 2014, 16:04:07
Thanks Mark. Something to check out then! Any idea on how I can test it?
RIP Paul Lovejoy
Webby the Bear
Quote from: Webby the Bear on 10 January 2014, 16:07:46
Sorry what I should have said was...
How much slack is acceptable?
RIP Paul Lovejoy
Webby the Bear
RIP Paul Lovejoy
Gaffers
Should be no slack at all, pull gently backwards to the firewall until you start to meet resistance then refit the clip :y
Webby the Bear
Thanks Guffer  :y Forgive my stupidity but what clip do you mean?  :-[
RIP Paul Lovejoy
