Author Topic: HID bulb upgrade help  (Read 7119 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« on: 11 January 2014, 13:03:05 »
I have a 2001 'y' reg facelift CD..
My lights are useless. They are the HID type I believe :o
I have polished the lens and this has helped but I'm wondering if the bulbs loose performance with age??????
What is the type of bulb I'm after ?
So ram night breakers seem to give greater brightness.
 Please help before I crash and die >:( :(
Omega 37
  • Northampton
Re: HID bulb upgrade help
« Reply #1 on: 11 January 2014, 13:35:51 »
OMG D2S how much  :D :'(
« Reply #2 on: 11 January 2014, 15:30:28 »
Do you have a manual level adjuster as part of the headlight switch? If so, you might see an improvement with Night Breakers (I've never sued them so don't know)
If there's no adjuster, then you have HIDs and I bet that the beam is pointing to the floor due to broken adjusters inside the headlamp itself. http://www.omegaowners.com/forum/index.php?topic=90638.0
Drive up to a wall/garage door & check where the beam is pointing to.
Keith ABS
  • Maldon Essex
« Reply #3 on: 11 January 2014, 16:22:09 »
  Yes, the lamps do lose performance after time. mine would do all the normal on start up, go through the colour change and then dim off. one of mine was yellow like an old sealed beam headlamp while the other was like the old dim/dip system in the 80,s. Worse lights I had ever had. a word of warning with replacements. The cheaper they are, the more problems there will be. My first replacement set would sometimes no strike up in cold weather until they both eventually refused to light at all. The next set I got online from HID direct or something like that. Got a discount so only paid £80 for the pair sent. Never had a problem since
Keith B
« Reply #4 on: 11 January 2014, 18:09:15 »
Bog standard projectors on the CD spec not HID.
As you say, Osram Nightbreakers :y
Omega 37
  • Northampton
« Reply #5 on: 11 January 2014, 19:00:07 »
a mate is getting me a pair of standard lamps so i will see if that does the trick before I shell out £150 on nightbreakers :y
« Reply #6 on: 11 January 2014, 21:11:21 »
Standard/projector lights shouldn't be as good as HIDs ..... as per the other post & above, there's something wrong with your HIDs if the light is poor. I'd suggest fixing what you've got rather than than going backwards with 'standard' lights.
« Reply #7 on: 11 January 2014, 23:46:03 »
 :o :o :o A pair of Osram Nightbreaker bulbs is around £12 ::)
« Reply #8 on: 14 January 2014, 15:48:02 »
Sorry to jump in on this thread, looking to upgrade all the bulbs on 03 CD can any one confirm the fitments for me please Dip/main/fog.
TIA.  :y
« Reply #9 on: 14 January 2014, 15:50:04 »
TIA.  :y
Seek and you will find (lazy sod) ;D ;D http://www.omegaowners.com/forum/index.php?topic=90457.0
Omega 37
  • Northampton
« Reply #10 on: 17 January 2014, 14:49:53 »
omg  >:( >:( >:( >:( >:( >:(
bought a pair of bulbs but they are H1  :-X :-X :-X :-X :-X :-X :-X
I had removed headlight bulbs from my old cdx 'w'w reg omega they are d2S  :'(
« Reply #11 on: 20 January 2014, 09:50:48 »
TIA.  :y
Was going to call you a cheeky sod but you got it in one.   ::) :-X :y
Martin_1962
« Reply #12 on: 26 January 2014, 10:20:08 »
Facelift CD used halogen projectors, CDX and up Xenons
I fitted aftermarket HIDs to mine
Omega 37
  • Northampton
« Reply #13 on: 26 January 2014, 22:54:15 »
yep just realised what projecters are :o
my cdx had the same lights but xenons, i thought the projector lens meant they were HID :o
chrisgixer
« Reply #14 on: 26 January 2014, 23:23:17 »
After market hids? What do these consist of Martin? Just a head light unit?
