Author Topic: Q for the radio transmitter experts  (Read 2512 times)
Taxi_Driver
Re: Q for the radio transmitter experts
« Reply #15 on: 12 January 2014, 20:12:50 »
So, is it the case that the data isn't getting through when the signal is perfectly OK for voice comms?
If so, I wonder if the radio is over / under deviating when sending data?
Sounds like it'd be better to rely on a smartphone app and internet connectivity in this day and age than squirting data down your PMR link, though. :-\
Yes.....
Anyways im confused a tad....some peeps says the freq is too close to another tx.....others says it should be fine......
One firm in Swindon uses a mobile network....not sure how that monitors the cars tho.....im gps tracked 24/7 when my data unit is on.....if they 'track' all their cars thats probably a fair bit of data they pay for  :-\
« Reply #16 on: 12 January 2014, 20:37:33 »
Well, I would say that the frequency issue is a red herring, as long as the radios are set up correctly they should co-exist happily. If the data uses different frequencies and power levels, then the fact that voice works doesn't prove a lot, other than the signal path is basically OK. If the data power level is a few db lower, then, if the voice isn't scratchy, I'd say the data should be working, so the question is why isn't it?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #17 on: 12 January 2014, 20:51:46 »
attenuation or signal quality?
Taxi_Driver
« Reply #18 on: 13 January 2014, 06:12:40 »
ok thanx guys, not that then.....
« Reply #19 on: 13 January 2014, 09:30:51 »
Does data performance inprove as you get closer to the base?
The question as to if the channel spacing is to small is very dependent on the quality of the transmissting kit (and to a lesser extent the receivers).
Given there are potentialy two 'more optimised' base sattions close together, the vehicle transmitters could easily be swamped by a poor local base transmitter nearby.
Taxi_Driver
« Reply #20 on: 17 January 2014, 19:30:35 »
Yes....tho my firm run 3 transmitters.....dotted about the town....to try to improve performance and cover blackspots....the other firm i mentioned runs two transmitters...
The receivers in our cars are 'suppose' to lock onto the stongest signal.....but doesnt always work..
« Last Edit: 17 January 2014, 19:35:51 by Taxi Driver »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #21 on: 17 January 2014, 19:43:07 »
On 3 different frequencies?.
Unless to System is Trunked or has Selective Voting, the Mobile will just pick a usable Signal not necessary the strongest one.
Page created in 0.029 seconds with 20 queries.
