Author Topic: Double DIN removal tools  (Read 9480 times)
« on: 13 January 2014, 17:10:27 »
Numerous sob stories on the forum about the difficulty in removing the double DIN units, mostly seem to involve poor quality removal tools, as I'm going to need some in the near (?) future are there any that should be particularly avoided, or even better, any that are particularly good ???
Interweb just gives a few hundred possibilities, with no indication of quality or ability to actually do the job !!
  • Online Online
Re: Double DIN removal tools
« Reply #1 on: 13 January 2014, 18:14:17 »
I've had reasonable success with the ones from Halfrauds, the trick is to 'wiggle' the unit I found, rather than out right strength.
Some just fly out, but a lot are real gits.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #2 on: 13 January 2014, 18:58:09 »
Some time ago I wanted to take mine out and simply used four skinny screwdrivers, braced inwards vertically, and pulled carefully. However, although this released it, I could not get the unit out completely and tried to shove it back in; it wouldn't go back fully! I've left it part-way sticking out - any thoughts on what I'm doing wrong?
Ron.
« Reply #3 on: 13 January 2014, 21:13:46 »
Ron.
You've bent summat :'(
Should have held the screwdrivers apart, so left hand handles to the left, right hand to the right...
That way you're compressing the spring tabs rather than bending the cage out, or not. :y
twiglet
  • Norwich, Norfolk
« Reply #4 on: 13 January 2014, 21:57:16 »
Nigel, I bought a set of the cheapo ones and then used a small file on the pins to create a nice 90 degree angle on them.  Pretty sure this is explained on one of the how 2's on here.
I must have used them more then 50 times on Omega head units now, and they have never failed me yet.
As already said, there is a knack to it. It's a case of making sure the pins are engaged and the spring tabs released before gentle pulling the unit out.  Brute force alone won't do it.
Some can be pretty tight, but in my experience these seem to be the CCR2006's rather than the NCDC's.  Whatever you do, don't apply any force at all the the fascia panel.  The clips are plastic and tiny, and break very easily.  Once broken, they are a pig to repair
Bigron
  • Witham, Essex
« Reply #5 on: 13 January 2014, 22:18:24 »
Thanks, Taxi Al, I'm sure you are right, but I can get the unit about 3/4 of the way out - would what you say still apply? And why won't it go back fully - same reason?
Ron.
« Reply #6 on: 13 January 2014, 22:20:13 »
many thanks all ..cheapo set and attack with the skinny file it is then .. :)
« Reply #7 on: 13 January 2014, 22:39:09 »
Ron.
3/4 out should be enough to see what is going on :-\ do you remove the screwdrivers once you've got it about an inch out?
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #8 on: 14 January 2014, 10:58:25 »
If you remove the ash tray and buttons surrounding the stereo, you can undo the screws holding the centre console in place. Do this and remove the whole section forward allowing you to access the pins either side of the stereo.
I know, because I couldn't get my stereo unit out either :y
AKA - Mr Bracket
« Reply #9 on: 14 January 2014, 11:05:41 »
Yes, nothing special about the tools, they are just a very tight fit inside the cage, IME.
Bigron
  • Witham, Essex
« Reply #10 on: 14 January 2014, 11:22:39 »
Glad to know that I'm not alone! I think when I summon up the courage I'll try taking the whole front off, as Blackviper suggested.
It all started after disconnecting the battery. Then I wanted to find the serial number to get the radio code from a site on Ebay, because the scaly-back who sold the car to me didn't supply the code - and it isn't in the documentation.
Ron.
« Reply #11 on: 14 January 2014, 12:24:56 »
Ron.
If it`s a CDR2005 or a CCR2006 you cannot get the code generated online from the serial number, needs to be "on the bench"
Bigron
  • Witham, Essex
« Reply #12 on: 14 January 2014, 15:31:07 »
Oh bugger - it's a CCR2006!
My pension won't stretch to any luxuries like having the radio back working, so I'll have to live without it......
Ron.
« Reply #13 on: 14 January 2014, 15:46:30 »
If you can remove it you may be lucky and find a previous owner has written the code on the unit
Bigron
  • Witham, Essex
« Reply #14 on: 14 January 2014, 15:55:32 »
I doubt it; the previous owner was an unhelpful a**e!
I tried again today; got it back to 3/4 out but no further - the metal casing came with it - is that normal(?) - and now it won't go back in as much as before, i.e. about 2 inches sticking out.
Ron.
