Drop Bike oil?
Started by tunnie, 14 January 2014, 13:04:12
Indeed, and oil temperatures could be much higher than in an Omega.
Given that Halfrauds are currently giving away fully synth oil for buttons, I wouldn't be putting semi synth in anything. (and won't, for a considerable period, given the stockpile I've now got). ;D
I've occasionally wondered why you haven't gone the DIY route on your bike before now, Mr Tunnie.
BMW flat twins have been about since the dawn of time, and are simplicity itself to work on.
Everything is so accessible that any work should be a piece of piss. :y :y
Quote from: Sir Tigger on 14 January 2014, 17:10:26
I think you should think more about what you're going to put in rather than when....  ::)
A quick scan suggests the recommended is 15w50 Fully Synthetic and it looks like BMW recommend Castrol, although I saw a suggestion that's for business reasons rather than engineering....  :-\
This is what's making me chuckle though.... You wouldn't chuck Castrol 15w50 full fat in your Omega just because you have some kicking around for your bike!  ;D
Your bike is worth a hell of a lot more than your Omega!! Do it properly!!  :D :D :D  ;D ;D ;D
Err I am, this thread was about when. I know exactly what oil I want to put in  ;)
As I previously stated 10/40 was BMW specified oil once apon a time, they change it several times a year!
15w50 huh? Well Opie oils have personally reccomended 75/90  :o  :D  ??? -  At a very reasonable £15 per litre  :o :o :o :o
Book for 2010 bike says:
Engine oil, capacity approx. 4.2 l, with filter change
Products recommended by BMW Motorrad
Castrol Power 1 Racing SAE 5W-40, API SL / JASO MA2
Engine oil, quantity for topping up max 0.95 l, Difference between MIN and MAX
http://www.bmw-motorrad.de/de/de/services/bmwmotorrad_betriebsanleitungen/com/PDF/R_0A01_RM_0213_R1200GS_01.pdf
Been doing a lot of research, 10/40 is fine:
http://www.r1200gs.info/forum/2-general-chatter/3143-10w-40-oil-1200gs.html
http://www.bmwmoa.org/forum/showthread.php?51510-10w40
http://www.ukgser.com/forums/showthread.php?91251-Oil
Quote from: Mr. Opti on 14 January 2014, 17:42:31
Mainly due to service history being important really on these, but it's less and less important now.  :)
It's a mine field looking online there are many different grades people use, but finally managed to get online manual of my bike, it specifies:
Engine oil, 20W-50
Is 10/40 really that different for UK use?
Given the age of the bike, fact it's not a 15,000 RPM racer, its a 2 pot tractor engine which has been pointed out a few times, also OOF has previously recommended 10/40 is fine for the bike  :)
Halfords thinks this is the best 20/50  :D
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_166289_langId_-1_categoryId_165581
Quote from: tunnie on 14 January 2014, 17:45:42
Er possibly for the gearbox perhaps....  ::)
Quote from: tunnie on 14 January 2014, 17:56:21
Engine oil, 20W-50
Well, that one's most certainly in the "not even in my lawn mower" category. :o
Quote from: Kevin Wood on 14 January 2014, 18:50:41
Engine oil, 20W-50
That is the only one they do, looks good  :o
So exact book for mine says 20/50, now my understanding is the numbers are linked to temps. So 10/40 would do just as well? In UK weather?
Quote from: Sir Tigger on 14 January 2014, 18:47:49
Thought it was pricey   ;D
15/50 still not right one though  :)
chrisgixer
Oh just change it. Any old oil will do its only a boxer twin, its a pre war design. It's hardly stressed either.
Quote from: chrisgixer on 14 January 2014, 19:29:34
That was my original thinking. But I'm being told to do it right  ::)
Quote from: tunnie on 14 January 2014, 19:45:53
Is that pre Boer war or pre Napoleonic wars?...... ::) ::) ::) ;D
A bmw with working indicators  ::) ;D :P
