Peugeot 106 brake light issue?
Started by Del Boy, 15 January 2014, 13:13:40
henryd
Quote from: Del Boy on 15 January 2014, 17:44:19
Just got one of my lads to have a look at the back lights, apparently they're dry as a bone? No water inside or around them, although he did sound rather uninterested ;D.
Pull the multiplug off each light and check for corroded pins,normally the earth pin and causes all sorts of weird shit :-\
other rides
hoofing it
Check to see if some tit has forced put the stop/tail bulbs in the wrong way round.
Webby the Bear
Followed a 206 back from town today.... brake light continuously on  ::)
RIP Paul Lovejoy
Quote from: Webby the Bear on 15 January 2014, 22:09:23
same as me the other day  ???
Webby the Bear
Quote from: Andy B on 15 January 2014, 22:16:53
You weren't in Northampton were you?  ;D
RIP Paul Lovejoy
Quote from: Webby the Bear on 15 January 2014, 22:25:10
I'd have been lost if I was ......  ;D ;D ;D
IIRC isn't the 206 the one with the master cylinder etc on the passenger side with a linkage under the carpet and a brake light switch the passenger can activate/break?
Certainly see plenty with the lights stuck on!
As for the 106 I'd say earth per the other posts. I'd also suggest pushing it off the cliffs at Dover.. ;D
Quote from: hoofing it on 15 January 2014, 21:47:48
What he said ^^^^^^
Almost certainly a retarded bulb changer who put bulbs in wrong (or even wrong bulbs!) ;)
