LPG mpg and cost per mile Q...
Started by 05omegav6, 19 January 2014, 21:01:20
Only question I would ask on the fuel consumption figures you use ... are they also from taxi's ?? or from more "normal" usage ?? I can see a taxi having much higher fuel consumption than a "normal" car .. in which case the LPG option becomes even more favourable .... the more you use the more you save ....
Quote from: Taxi Al on 19 January 2014, 21:50:47
Quote from: Sir Tigger on 19 January 2014, 21:43:06
Quote from: Taxi Al on 19 January 2014, 21:33:01
Quote from: Sir Tigger on 19 January 2014, 21:30:21
Quote from: Taxi Al on 19 January 2014, 21:10:32
Have I missed anything else :-\
The VXR8 might not be suitable for taxi work?  :-X  :-\  ;)
Loads of room in it and a massive boot... what more is required ::)
Besides, it's hypothetical...
Hypothetically speaking wouldn't the LPG tank take up about 1/3 of the mahooooosive boot?  :D  ::)
Not if it's in the spare wheel well where the Full size spare used to sit, silly :P
Indeed they are Nige :y
Every diesel car I've driven for work has settled at 35mpg, so that is the benchmark for that.
The lpg figures are from an earlier VXR8 that does a mixture of taxi work and hooning around, so broadly similar to my current use :y
Quote from: Sir Tigger on 19 January 2014, 22:07:27
That was meant to be tongue firmly in cheek  :-[ spare can live in the garage :y
Quote from: Taxi Al on 19 January 2014, 22:09:57
In which case .. Vectra @ 35 mpg diesel = 18.16 pence / mile
VXR8 @ 18 mpg on LPG = 18.16 pence/mile ....
absolutely the same !!!  so a small amount of petrol every startup on LPG and the cost of the conversion to factor in ..
:y :y :y
Quote from: Taxi Al on 19 January 2014, 22:11:27
That's OK, hypothetically you only need a can of squirty goo anyway!  ::)  :)
Quote from: Sir Tigger on 19 January 2014, 22:18:46
It's fine, I have AA cover, what's the worst that could happen ;D
