Pages: [1] 2 3 4 5   Go Down
Author Topic: Speedometer not working  (Read 16088 times)
Kate
  • Cornwall
    • Drives people mad
« on: 22 January 2014, 10:31:13 »
Hi all.
My speedometer isn't working. Are there any guides about this issue that I could have a look at? Or does any know how to fix it?
Any help would be greatly appreciated. :y :-* :-* :-*
Re: Speedometer not working
« Reply #1 on: 22 January 2014, 10:40:02 »
Are there any warning lights on?
Kate
  • Cornwall
    • Drives people mad
« Reply #2 on: 22 January 2014, 11:50:50 »
No, there's no warning lights on.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 22 January 2014, 13:49:10 »
And ABS light comes on at start up and then goes off and stays off?
Any wierdness with steering going really heavy from time to time?
Kate
  • Cornwall
    • Drives people mad
« Reply #4 on: 22 January 2014, 13:59:41 »
Yes I think that ABS light comes on then goes off and stays off.
Never noticed any steering problems yet but I'll check again today.
Thanks for helping me. :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #5 on: 22 January 2014, 14:05:26 »
Speed sensor or the gauge fubar'd. I'd look at speed sensor first.
Is it auto? If so is it shifting ''oddly''?
RIP Paul Lovejoy
Varche
    • Golf Estate
« Reply #6 on: 22 January 2014, 14:29:19 »
I was only thinking it might be the dreaded ABS ECU failure.
My guess is it isn't. That is good news.
You would know if the steering had gone heavy at any stage.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #7 on: 22 January 2014, 15:00:51 »
Easiest place start would be to pull the Clocks Housing out. re fit making sure the Main Centre Connector is home properly.
« Reply #8 on: 22 January 2014, 15:05:58 »
What he said :y
Kate
  • Cornwall
    • Drives people mad
« Reply #9 on: 22 January 2014, 16:50:46 »
Been out in it today. The ABS light never came on at all and neither did the TC light.
Does that make any difference?
Steering and gearbox are perfect.
Kate
  • Cornwall
    • Drives people mad
« Reply #10 on: 22 January 2014, 16:58:11 »
Yes it's an auto.
« Reply #11 on: 22 January 2014, 17:33:53 »
Someone might have whipped the bulbs out to hide the fact the abs ecu is duff ::)
Kate
  • Cornwall
    • Drives people mad
« Reply #12 on: 22 January 2014, 18:03:53 »
So how do I fix it?
« Reply #13 on: 22 January 2014, 19:28:16 »
First thing is to establish that neither the ABS nor TC lights illuminate when the key is turned to position 2.
If they don't, then pop the cluster out to confirm whether the bulbs are there or not.
If not, what you do next depends on a couple of things, where you bought the car from and how much you paid for it...
Did you test drive the car, and was the speedo working then?
Lots of questions, I know, but the answers will help find the right solution :y
Kate
  • Cornwall
    • Drives people mad
« Reply #14 on: 22 January 2014, 19:38:25 »
Thanks Al.
No the ABS an TC lights never light up at any time. Is it difficult to take the cluster out?
I bought the car cheap, knowing that it needed work. I only did a short test drive so didn't notice if the speedo was working or not.
It was a private sale.
Pages: [1] 2 3 4 5   Go Up
