Pages: 1 2 3 4 [5]   Go Down
Author Topic: Speedometer not working  (Read 16113 times)
Re: Speedometer not working
« Reply #60 on: 29 January 2014, 20:54:34 »
Is it possible to buy an ABS ECU or is it best to repair the one that's on the car?
The one you buy second hand might just be about to fail, as this is a fairly common fault. £130 for a repaired one with a two year warranty is, IMHO, the most economic solution.
I wouldn't be able to remove the old one so that's a big problem.
Can the car run without one installed btw while the part is being repaired?
Removal is "only" 6 bolts .. takes about 30 minutes !! - you only remove the ECU from the end of the ABS pump block and unplug it  .. :) (refitting takes a while longer and fills the swear box)
As yours is not working and you are happily driving then that will continue ... :)  Once you get the new one fitted BE CAREFUL .. you'll suddenly find the power steering now works as well !!! :)
Kate
  • Cornwall
    • Drives people mad
« Reply #61 on: 29 January 2014, 21:18:59 »
The PAS is already working.
Have I been looking at the wrong guide as it sounds complicated?
http://www.omegaowners.com/forum/index.php?topic=90627.0
« Reply #62 on: 29 January 2014, 21:27:51 »
As there is no ABS input, the servotronic PAS is giving a constant "default" assistance .. not the variable with speed assistance you should be getting :)
as Jimbob says in #3 ..it sounds alot but is easier than you think ..
Kate
  • Cornwall
    • Drives people mad
« Reply #63 on: 30 January 2014, 13:42:14 »
Had a look at the connector on the info screen today and it's fine.
The screen must just be dodgy. :-\
I_want_an_Omega
« Reply #64 on: 30 January 2014, 14:07:07 »
Can you post a picture(s) up of it please Kate - showing as much on the screen as poss - I'll be able to see if mine will do the job.
Its a shame its back in (I assume) as a part number would be useful .........
Kate
  • Cornwall
    • Drives people mad
« Reply #65 on: 30 January 2014, 21:06:43 »
It looks exactly like this one on ebay:
http://www.ebay.co.uk/itm/VAUXHALL-OMEGA-2001-4-MODEL-PIXEL-DASH-DISPLAY-PART-NUMBER-24400698-BL-/231141867280?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35d120ff10
I can take it out and find the part number if that's more accurate?
Thanks for helping. :y
« Reply #66 on: 30 January 2014, 21:11:09 »
The key is the number and colour of any plugs on the back of it :y
« Reply #67 on: 30 January 2014, 21:11:18 »
Replacement MID has to have right config...  ...tech2 to change config.
You may have blown one of the 3 or 4 bulbs (depending on type), making one part look brighter or dim?
« Reply #68 on: 30 January 2014, 21:13:13 »
If computer lines are above radio info line, its single grey connector. These types are uber reliable, and fitted to post 1998 cars.
If computer lines are below radio info line, its the twin black/yellow connector, and suffer lines of pixels failing. Fitted from 1994-1997.
Kate
  • Cornwall
    • Drives people mad
« Reply #69 on: 30 January 2014, 21:15:06 »
No I tried changing the bulbs but it had no affect.
Some of the pixels in the centre part of the screen have died so the letters look incomplete.
Kate
  • Cornwall
    • Drives people mad
« Reply #70 on: 30 January 2014, 21:22:20 »
Like this but the top and bottom parts are nearly perfect:
The display on mine has the grey connector.
So how would I fix it?
Thanks TB. :y
« Last Edit: 30 January 2014, 21:24:38 by Kate »
« Reply #71 on: 30 January 2014, 21:27:15 »
I'd replace it Kate. So reliable, the grey connector ones are worthless. Sadly, I lost all my spares in the fire, else I'd post you one.
Config needs to match - press both S and R together for 5s, you should get 3 numbers, post these up.
Kate
  • Cornwall
    • Drives people mad
« Reply #72 on: 01 February 2014, 19:36:40 »
Thanks. :y
Just been out in the car and the screen has returned to normal!
I always wanted a self repairing car. ;D
« Reply #73 on: 01 February 2014, 20:01:12 »
Thanks. :y
Loose connection somewhere from when you checked the bulbs ??
Kate
  • Cornwall
    • Drives people mad
Pages: 1 2 3 4 [5]   Go Up
