Author Topic: 2.2 dti screechy turbo  (Read 2982 times)
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
« on: 23 January 2014, 13:30:37 »
Hi. My 2.2 dti makes a loud screechy noise, that appears to follow the turbo. Although it has no EML and it seems to boost as it should. I have changed the turbo, downpipe gasket and manifold gasket, and it still makes the same noise...  :-\
The pipes to and from the intercooler look free from splits or oily marks from an air leak, as does the intercooler. Does anybody know of any common problems that cause this? Or a way to pressurise the inlet to find out?
Thankyou in advance.
Artificial intelligence is no match for natural stupidity...
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: 2.2 dti screechy turbo
« Reply #1 on: 23 January 2014, 14:57:11 »
Landrover TD5's do this when the inlet manifold warps slightly causing a small boost leak,maybe something similar occurring here ???
other rides
martin42
« Reply #2 on: 23 January 2014, 14:58:34 »
My zafira 2.0 dti used to make that noise,never could find out what it was.
andymp
  • Wakefield, UK
« Reply #3 on: 23 January 2014, 15:29:45 »
After something of an epiphany, I used the compressor to pressurise the inlet and a screech came from the inlet side, poured water on it and the inlet manifold gasket bubbled...
andymp
  • Wakefield, UK
« Reply #4 on: 23 January 2014, 15:34:56 »
Excellent guess, Henryd...  :D
martin42
« Reply #5 on: 23 January 2014, 15:59:24 »
Whats caused it to do that ?
andymp
  • Wakefield, UK
« Reply #6 on: 23 January 2014, 16:20:19 »
Admittedly, last time I cleaned the swirl block, I was given the wrong gasket so I reused the old one... a new one on order from the stealership for tomorrow...
martin42
« Reply #7 on: 23 January 2014, 16:31:21 »
Well at least i now know what it was  :y
henryd
  • west cornwall
« Reply #8 on: 24 January 2014, 09:19:22 »
Result,lets hope it is that :y :y
other rides
andymp
  • Wakefield, UK
« Reply #9 on: 24 January 2014, 19:05:59 »
Got a gasket, £6.64 from the stealers... what a difference. No screech, no vibration at low revs under power, no flat spot at 1500 rpm, no smoke, quieter...  :D
henryd
  • west cornwall
« Reply #10 on: 25 January 2014, 11:51:14 »
Happy days :y :y :y
other rides
