Author Topic: XENON Ballast Box  (Read 5661 times)
egcc
  • manchester
  • Omega 2.6 2003 Auto
XENON Ballast Box
« on: 29 January 2014, 17:12:19 »
Hi all, sorry if there is already a thread regarding the same .. I have tried to find one  with no joy.
I have a Omega 2003  model with xenon lights.
The passenger headlight some times lights up and sometimes does not when I turn on the lights.
When it does light up after turning on and off quickly the bulb will stay on for ever, until I turn it off again.. and then the same procedure is required in most cases.
I think the ballast maybe at fault.. is there a vid showing how to replace it or its location, any information will be appreciated.  I have seen a replacement on ebay  with a bulb  >>  http://www.ebay.co.uk/itm/VAUXHALL-OPEL-OMEGA-XENON-HEADLIGHT-BALLAST-PACK-PHILIPS-BULB-GM-90565932-/310705648275?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVauxhall%7CModel%3AOmega&hash=item48577ff293
Thanks in advance.
Vauxhall Omega  2.6 CDXI Auto 2003 Saloon https://en-gb.facebook.com/TheDeadXiii
Re: XENON Ballast Box
« Reply #1 on: 29 January 2014, 17:17:40 »
PM sent.
Have you tried swapping bulbs?
I_want_an_Omega
« Reply #2 on: 29 January 2014, 17:18:17 »
I have one of these which you can have for half that!
PM me if you are interested  :y
egcc
  • manchester
« Reply #3 on: 29 January 2014, 17:26:37 »
PM sent.
If the bulb is defective...  could it light up as normal one day and not the other?  unsure so I thought maybe the power/Ballast.
egcc
  • manchester
« Reply #4 on: 29 January 2014, 17:37:06 »
I will remove the headlight at the weekend and see if there is any poor connections to the ballast,  or borrow the ballast from the other side to test.
Is the Ballast easy to get to?
Thanks again
amba
  • Medway towns
    • German V6
« Reply #5 on: 29 January 2014, 18:17:59 »
Ballast unit is machine screwed to underside of headlight unit so can only be removed with entire headlight out of car.
Be carefull when removing the light unit as the sharp edges of the ballast can quickly scratch bumper paintwork..I put a thick towel on the bumper to protect .
Word of warning...disconnect battery earth and leave car for around 1 hour before touching lights as yo want all the stored energy in ballast to have gone..nasty shock if not. :o
egcc
  • manchester
« Reply #6 on: 29 January 2014, 18:24:29 »
Thank you for your help..
« Reply #7 on: 29 January 2014, 19:16:38 »
Does sound more like bulb. Does it have a purple tinge to it?
« Reply #8 on: 29 January 2014, 22:52:28 »
Easier to swap bulbs from side to side to see if bulb or ballast ;)
egcc
  • manchester
« Reply #9 on: 03 February 2014, 12:14:39 »
Hi, Will remove headlight today and possibly swap the ballast... before I do.. can the ballast be removed without actually opening up the sealed headlight or is the replacement simply external.
Thanks in advance.
« Reply #10 on: 03 February 2014, 12:35:11 »
Thanks in advance.
Yep, self-explanatory once light unit is removed
egcc
  • manchester
« Reply #11 on: 03 February 2014, 12:42:04 »
Thanks Rob.  :y
egcc
  • manchester
« Reply #12 on: 03 February 2014, 14:44:47 »
Thanks all for your help .. I changed  both ballast and bulb just incase... all is working .. bring on the darkness  ;D
Keith ABS
  • Maldon Essex
« Reply #13 on: 03 February 2014, 18:42:49 »
  If it has a cheaper lamp fitted then it will do this. had the same problem until one day both decided not to light up again. the more you pay for replacement lamps, the better they will be. My replacement pair cost £75 posted
Keith B
