Pages: 1 [2] 3  All   Go Down
Author Topic: Need a shed  (Read 5849 times)
78bex
    • 2.2 CD AUTO / FAZER 600
Re: Need a shed
« Reply #15 on: 03 February 2014, 22:53:47 »
I really like this one with the roller door, you can see the build sequence they use
https://www.youtube.com/watch?v=JdunL7adqd0
2woody
  • Northumberland
Re: Need a shed
« Reply #16 on: 03 February 2014, 23:03:17 »
you've got a welder, haven't you ?
Re: Need a shed
« Reply #17 on: 03 February 2014, 23:47:24 »
Been looking for a house with double garage. Preferably "en-suite" from the kitchen.
That one next door to me is still up for sale .. double garage is two long rather than wide, though, sadly .. and I happen to know they rejected an offer of £315,000 on it so they're a little optimistic on it's value considering it needs the kitchen and bathrooms gutting (unless you like 1980s kitchens and 1970s lilac bath suites!)
chrisgixer
Re: Need a shed
« Reply #18 on: 03 February 2014, 23:48:52 »
Wood though. Too much condensation in metal.
Plus it's the drainage that's my concern, the garden slopes into that corner where the existing shed is. Hence the damp, I suspect.
We inherited it when we moved in, so not sure what's under there currently.
chrisgixer
Re: Need a shed
« Reply #19 on: 03 February 2014, 23:53:16 »
That's partly why we rejected it, tbh. Been through a bathroom and kitchen here. I'm in no rush to go through that again. If they are serious about the sale they need to sort it.
Its over priced at 340k. And it's not a 4 bed as they claim. Plus we'd loose side by side parking for three cars like we just about have here.
But that utility would get knocked into the garage if at all possible. ;)
« Last Edit: 03 February 2014, 23:58:17 by chrisgixer »
Re: Need a shed
« Reply #20 on: 04 February 2014, 12:45:28 »
Aye, they're being greedy - it was originally listed for less I think, with the agents I had out the other day. As he said, they've been there for three billion years so whatever they sell for they've made a tidy profit, and anyone coming in is going to want to gut the place..
Re: Need a shed
« Reply #21 on: 04 February 2014, 15:08:34 »
A decent solid base for starters  :y Dad got a ready built one 8x6 and they came and put it up on the base he built for it . Nice and strong shed , not that big but enough to put his garden tools in and potter about in with a small work bench . I built my own 4 yrs ago 12x10 , the roof leaks quite bad now  :'(
Re: Need a shed
« Reply #22 on: 04 February 2014, 16:29:22 »
You've seen mine... Wasn't cheap but worth every penny :y
Phil
Re: Need a shed
« Reply #23 on: 05 February 2014, 16:18:29 »
Lightweight Kingspan SFS or Metzec studs, cement particle board on the out side, insulate depth of studs with Rockwool soft rock, then 9mm ply on inside.
Make the front (or one side) higher than the back (or other side) so its a mono pitch roof, insulate roof with Kingspan K15 on top of CP board and cover in Sarna single ply membrane, creates and insulated inverted roof and clad the CP on the walls with anything you like. Warm, dry and won't rot.
Its how I've (nearly) built a 3m*2.4m 'shed'
Mine also has a Schuco leaf and 1/3rd secure by desgin full glazed door, I covered the concrete base in Liquid Plastic structural waterproofing and in total it hasn't cost me a penny apart from my time.
Guess working on a £14m caldding project where theres a bit of left over helped :-)
« Last Edit: 05 February 2014, 16:20:55 by Phil »
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
Re: Need a shed
« Reply #24 on: 05 February 2014, 19:01:53 »
I've just got an order (for a friend of a friend) for a timber workshop 20ftx12ft, with a pent roof, to be built out of scaffolding boards.
route a groove down the long edges of each board to be splined with 15mm ply (which I get free, but would cost about £35 a board, ripped to 1in wide - you'd need two full boards.).
9in wide scaffold boards = 70 of them to form 3 walls (set vertically).
Scaffold boards are 13ft long, so cut in half for a 6ft6 wall - 35 at £6.50 each (50p/ft from my local supplier, I'd ask for a bigger discount if I build them regularly)
another 160ft for three horizontal rails to tie the walls together + another 11x13ft for rafters = another 300ft (which could be reduced to 150ft if you ripped all the boards lengthwise.
gives a grand total of £377. + 15% wastage = £450 in timber + base + roof.
That'll give you walls of 1.5in thick timber, which nobody's going to break through anytime soon - no condensation problems, reasonably good insulation, and if you want to hang a shelf, just screw it straight to the wall.
Carpe Incendium
Re: Need a shed
« Reply #25 on: 05 February 2014, 20:25:50 »
Plastic Sheds? Costco were flogging one about 10x12 for about £700 when I was there with tunnie (cant remember when that was  :-[)
chrisgixer
Re: Need a shed
« Reply #26 on: 05 February 2014, 20:46:34 »
Hmmm. I don't think anything off the shelf will be suitable tbh. I need doors in certain places. Might get away with a modular design with sections that can be arranged as I want them if such a thing exists, but it's looking like a trip to the Timber yard at the very least.
Will need to lay a solid base and sort some drainage to a soak away.
Re: Need a shed
« Reply #27 on: 05 February 2014, 20:56:27 »
Sounds like you need to make/have made.
I was lucky, I found the ideal shed for my needs, off the shelf. It just so happens that I probably didn't need a shed after all (although those who'd been in my garage would probably disagree ;D)
Re: Need a shed
« Reply #28 on: 05 February 2014, 23:00:05 »
Mine could have been customised.... In fact it was :y All are built to order ;)
Re: Need a shed
« Reply #29 on: 06 February 2014, 17:09:16 »
LD, mind if I ask where from and how much (impertinent question, I know.. Feel free to PM that bit if you are ok answering!)?
Asda direct of all places have some well priced large sheds that might suit me, though not Chris by the sound of it.
Pages: 1 [2] 3  All   Go Up
