Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: Simpler days  (Read 14560 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Simpler days
« Reply #75 on: 07 February 2014, 00:06:52 »
Mk5 Cortina has a roofline 1.5" higher than a mk4 which is a pretty major change! Although estates are the same.  ....
You sure?  :-\ years ago, a neighbour bought a saloon door for his MK4/5 Cortina estate. Fitted great at the bottom but was short in the glass!  ;D ;D ;D
Positive. My W plate radiant red 1.6Gl saloon was bought for £25 with stoved in NSF door. After MOTing, and servicing it, I used it for my 90 mile round trip every day. 3 months in, I finally acquired a perfect door off a white mk5 estate for £10. Yes, I bought a door for nearly half what I paid for the car. What could possibly go wrong? I cleaned and painted it, and fitted it one Saturday afternoon. It fitted perfectly at the bottom as you said, but there was a 1.5" gap between the door frame and roof. Which gave my club members a laugh that evening when I mentioned it, as they all knew that a mk5 had a higher roof than a mk4.
I had a good thrash every morning between the M23 and Manor Royal, as the bloke in the 325 had this weird thing about slowing down for roundabouts. Did that everyday for 5 months!
  • Chatham, Kent
Re: Simpler days
« Reply #76 on: 07 February 2014, 00:15:02 »
Those Cologne V6s certainly took some fettling... ;D
Oil changes every 6k, tappets and plugs every 12k, plus another 3k of trying to stop the rocker cover gaskets from leaking ::)
And that's without worrying about rust and coolant loss...
Remind me, what is the oil change interval recommended here for an Omega V6?
Dry rocker covers are simple; get a pair of alloy covers and the late rubber gaskets from Ford. Job done. Although they were rare, and are now outrageously expensive - the last ones I sold 10 years ago went for £100 a pair. Failing that, you just straighten the flange(just like any other pressed steel cover from the last 80 years), use the spreader plates from a Pinto cam-cover and forget about it.
Coolant loss on a Cologne is down to the thermostat or water pump, both of which suffer from very long, M6 bolts which are incredibly easy to snap off. It's really rare to find a replacement waterpump that doesn't have at least one broken bolt.
Re: Simpler days
« Reply #77 on: 07 February 2014, 00:31:07 »
Got most of those TShirts ;D
Wasn't aware of alloy covers or rubber seals, even my early Mk2 XR4x4 had cork gaskets ::) that was a definite improvement that the 2.9 brought with it... self adjusting valve gear ;D
Pages: 1 2 3 4 5 [6]   Go Up
