Author Topic: Cutting out when hot no warning lights  (Read 4465 times)
Irmsherelite3.2
  • Cumbria
    • 3.2 elite
« on: 06 February 2014, 18:09:59 »
I recently mentioned I had a bit of a water leak from a blocked scuttle panel that drained my battery, I got that sorted and dried out, put car into a local garage for a slight leak from camshaft cover, ever since getting it back it has been cutting out when hot and refusing to start for ten minutes or so then starts and runs fine.
Reading the forums i get the idea it may be a worn crank sensor, or possibly a knock sensor trapped when they have sorted rocker cover gasket.
Any other ideas as i only get fridays off and dont see daylight the rest of the week.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Cutting out when hot no warning lights
« Reply #1 on: 06 February 2014, 18:11:02 »
Paper clip for codes. Crank senor symptoms  :y
RIP Paul Lovejoy
« Reply #2 on: 06 February 2014, 18:17:04 »
Can do pedal trick on DBW Webby  :y
Sounds like crank sensor, do a pedal test and check for codes.  :y
Webby the Bear
  • Northampton
« Reply #3 on: 06 February 2014, 18:18:45 »
Yeah what he said  ;D
RIP Paul Lovejoy
chrisgixer
« Reply #4 on: 06 February 2014, 23:31:48 »
See pedal trick in maintenance, as they guys said.
If you see 0335 (iirc) that is a crank sensor fault.
chrisgixer
Irmsherelite3.2
  • Cumbria
    • 3.2 elite
« Reply #6 on: 07 February 2014, 05:01:42 »
Thanks guys was well depressed, last thing i want to do is scrap the old girl, only on 69 thou now!
Big_Al
« Reply #7 on: 07 February 2014, 06:56:27 »
Genuine Bosch crankshaft sensors for 3.2 /2.6  on offer at Vauxhallworldparts .com   at Grays Essex . . . .  £51  inc. VAT :o :o :o :o
« Reply #8 on: 07 February 2014, 08:54:42 »
Sounds like cranksensor, put post up the codes stored in ECU (pedal trick) first.
3.2 takes the cheaper of the 2 cranksensors, around £50 on Tradeclub for genuine part (use genuine GM part for this item, patterns and "Bosch branded" seem to be problematic).
Big_Al
« Reply #9 on: 07 February 2014, 17:06:55 »
 :-\ Are these "Bosch"  branded not genuine Bosch then ?  As in counterfeit :o :o
I would have thought  being Bosch they would be the same as the GM / Bosch part  . .same Bosch part no.
GM one was £99 .00  + the vat from my local stealer  . . hence I went down  the, what I thought was the genuine  Bosch route
« Reply #10 on: 07 February 2014, 17:21:26 »
£72 all in for the last VX one I bought two weeks ago :y
Will pop the pn up in a mo...
« Reply #11 on: 07 February 2014, 18:08:09 »
90540743 :y
« Reply #12 on: 08 February 2014, 10:26:19 »
Its hard to tell, but we see a number of people who have cranksensor problems buy Bosch ones from egay (pretty much guaranteed to be counterfeit) or back street factors, and the problem doesn't go away, until they then buy another genuine one.
Like you, I'd imagine that a genuine Bosch one would be almost the same as what they supply to GM (not sure if they make it specifically for GM for things like cable length etc).
IMHO, given that the genuine one for most of us is £46.12 + VAT on TC, I don't think its worth the risk paying £50 for a potentially problematic (fake or just not quite the same as GM) on in order to save a few quid.  Remember, on our V6s, a problematic cranksensor will leave us stranded.
« Reply #13 on: 08 February 2014, 10:27:13 »
90540743 :y
Should be £55.35  :-\
Big_Al
« Reply #14 on: 08 February 2014, 17:24:29 »
Thanks for reply TB . .   I am concerned now that the one I fitted may not be genuine Bosch . . . . although no problems as yet .
It came in a nice yellow Bosch box  & was sealed in a Bosch part No.  labeled plastic bag  ::) ::)
As the crank sensor had already been changed on my car 35k miles ago , I was able to retrieve the old one complete And compared it to the new so called "genuine Bosch" replacement  . .  it was exactly the same including  length of cable  :-\
Do the GM supplied ones have GM on them as well as bosch then ?
As I don't have another as a spare i will get a GM one ASAP to put in the boot for emergency use
When pricing up the options The alarming man was also quoted £99 + vat from his local stealer :'( :'( . although his & my quotes were retail I believe :-\
I asked the parts guy to check it was the right one as it seemed expensive  . . . his answer was "there is only one listed for the 2.6 and it's £99.00 + vat "   :o :o :o
« Last Edit: 08 February 2014, 17:26:21 by Essex Big Al »
