Author Topic: Easy start - diesel engine?  (Read 7785 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Easy start - diesel engine?
« Reply #15 on: 12 February 2014, 11:44:18 »
Easy start. Mmm brings back memorys,
 get long tube stick in air intake on FSIE when flat out give big squirt, whoooosh 2-5mph faster. And use same tube and can on tractor could get flames out the exhaust, are mispent youth..... 8)
FSIE's were soooo slow.....my Suzuki TS50 was much faster :D :D
yeah wanna race to the wreck and back ;D
my FS1E had drops, micron expansion, 300 or 350 rear tyre,skimmed head,raised and widened exhaust port, YB 100 carb, modified disc valve and did 68mph, we was cooking on 5star aswell..
so ya still wanna race then :D
Hoof'land storeman.
« Reply #16 on: 12 February 2014, 14:03:08 »
A mate of mine had a Puch Maxi.. and another had a Raleigh Wisp. :D Does it get any worse than that?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17 on: 12 February 2014, 14:17:04 »
Honda Express?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #18 on: 12 February 2014, 14:19:41 »
It could have been worse, he could have had an SS50 or even a C50/70/90  :'( :'( :'( :'(
I love the smell of Easi-Start   mmmmmmmmmmm :y :y
Well, they do call it "Laughing Gas"...probably because it is!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
« Reply #19 on: 12 February 2014, 15:26:25 »
Easy start.....grrrrrrr......mutter......(shakes head)......  >:(
« Reply #20 on: 12 February 2014, 16:00:21 »
Have a read of this:
http://www.omegaowners.com/forum/index.php?topic=119825.0
As I cant be arsed typing it out again  ;D
« Reply #21 on: 12 February 2014, 16:22:18 »
Honda Express?
Luxury. You didn't even have to pedal that along like a bike to get it started.. Mind you, that feature was a handy backup when it wouldn't start. ::)
« Reply #22 on: 12 February 2014, 17:03:05 »
My mate had a Puch Maxi (with pedals) and how we laughed!!  Until he left us in a cloud of dust, as it was the fastest 50 in town!  ::)  ;D
« Reply #23 on: 12 February 2014, 17:30:07 »
My mate managed to get knocked off his by our maths teacher's wife. We didn't laugh much! ;D
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
« Reply #24 on: 12 February 2014, 19:51:11 »
Dont ever use easy start. The need to means something else is wrong.
If its been run low on fuel, the fuel system will have air in it. To bleed the low pressure side, carefully pull the leak back pipe off above the inlet manifold where it starts to branch into four, hold the piece that runs down to the injector pump union and apply suction. This will draw fuel into the filter housing. Once you get diesel to the end of the pipe, quickly reconnect it back to where it branches off.
If necessary, to bleed the high pressure side, slacken the 4 17mm unions where the injector pipes meet the injectors below the end of the leak back pipes, without disturbing the leak back pipes if possible... and turn the engine over on the key until fuel spurts from the injector unions (This wont work with the leak back pipes off). Tighten them back up and the engine should start. Albeit a little groggy at first.
The engine appearing to run out of fuel when the tank is 1/8 to 1/4 full (especially when parked nose upwards) means the swirl pot in the fuel tank pickup needs cleaning out. In particular the spring loaded valve at the base of it.
« Last Edit: 12 February 2014, 19:53:23 by andymp »
Artificial intelligence is no match for natural stupidity...
JDX
  • Hersham, Surrey.
    • '02 2.2dti CDX estate.
« Reply #25 on: 13 February 2014, 08:53:41 »
[/quote]
Thanks for the advice.....it has only happened the once, I think it is unlikely to be a residual problem but should it happen again I will have a go at this if it's not too involved!! ::) I will have a look further into how to do this.  ;)
andymp
  • Wakefield, UK
« Reply #26 on: 14 February 2014, 22:03:50 »
http://www.omegaowners.com/forum/index.php?topic=90611.msg1155520#msg1155520
its for the 2.5 but the 2.2 is the same other than the absence of an electric lift pump.
« Last Edit: 14 February 2014, 22:06:22 by andymp »
