Author Topic: Gearbox solenoid wanted  (Read 2481 times)
« on: 13 February 2014, 18:04:28 »
3-4 solenoid wanted please in known perfect order :y
ted_one
Re: Gearbox solenoid wanted
« Reply #1 on: 13 February 2014, 18:47:07 »
Have you checked out the price of one from JPAT yet James?
« Reply #2 on: 13 February 2014, 19:08:10 »
I had a pressure control solenoid from them once, caused an awful 3-4 change, when replaced by GM one it was fine...
ted_one
« Reply #3 on: 13 February 2014, 19:18:12 »
I'd better start looking for one as well then :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 13 February 2014, 21:25:40 »
 I have a valve block from an ar25 from which I only need the 2-3 solenoid, not sure if the others will fit your box ? Not sure how to remove the solenoids, got the roll pins out but they seem to want to stay in the housing
Martin_1962
« Reply #5 on: 14 February 2014, 13:10:56 »
Since you are local and buying my LPG. If you can extract the gear box, you can have the valve and other parts off it for free.
I am dreading going underneath to remove everything and it will make engine removal easier.
Box is OK not the best but it changed gear fine.
Anything you don't wan't can go in the boot for scrap when you have picked up the gas tank.
