Author Topic: Rear coil springs  (Read 2055 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Rear coil springs
« on: 13 February 2014, 21:22:57 »
I'm changing the rear coil springs this weekend, does the car need to be in neutral with the handbrake off, mines automatic?
Re: Rear coil springs
« Reply #1 on: 13 February 2014, 21:24:46 »
Yes and yes, helps diff drop lower :)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #2 on: 15 February 2014, 14:03:23 »
Would it be possible to use spring clamps to compress the springs and remove them with out the need to lower the diff?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #3 on: 15 February 2014, 15:08:49 »
I doubt it, I've just done mine last week. PM me if you get any probs. :y
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #4 on: 15 February 2014, 15:47:32 »
Dropping the dif isn't as radical as it sounds(i thought ahh) at the time but it all went well.Found it easier with second person to open up gap to allow spring in/out without too much force
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #5 on: 16 February 2014, 14:24:44 »
The clip on the brake pipe is badly rusted. As you look at it from under the rear of the car, in what direction does it come off?
Shackeng
  • Ramsbury
« Reply #6 on: 16 February 2014, 15:44:10 »
There are two 'slide-in' clips, one each side. They are both the same type on my '99 TD. After soaking with plusgas mine both wriggled off nicely with mole grips on the flange pulling away from the bracket.
