Author Topic: Tapping noise on first start of the day.  (Read 2365 times)
Ady
  • Poole
    • Omega 2.6
« on: 15 February 2014, 10:42:53 »
When I start my 2.6 first thing in the morning I get a tapping nocking noise from the engine. Last about 3/5 seconds then goes.  Is this normal or is there a problem with the car?
Did an oil change last month but that didn't help it. I used valvoline 10/40 semi from GFS.
Also yesterday after parking it up for 2 days as I work away from home it was hesitant and juddering for fist 2 mins. Tho never done this before and was fine this morning pulling well with all it's power.
Any thoughts ??
Ady
Re: Tapping noise on first start of the day.
« Reply #1 on: 15 February 2014, 10:46:38 »
Did an oil change last month but that didn't help it. I used valvoline 10/40 semi from GFS. ......
Any thoughts ??
Ady
Sounds like a sticky 'tappet' The hydraulic lifters stick closed sometimes when they've been left with a cam lobe on them overnight. You've done an oil change, which is a good thing anyway, whether it helped or not. Wynnes do an oil treatment for sticky lifters - never used it myself, but seems to get good reviews.  :y
click here
« Last Edit: 15 February 2014, 10:48:50 by Andy B »
« Reply #2 on: 15 February 2014, 14:50:03 »
Works wonders :y
The iffy start is probably damp related, and sitting for two days will also allow the oil to drain completely from the heads. If it clears quickly then not a big deal... the lifter treatment will help. If it doesn't clear once the engine is hot then you have a problem :y
Ady
  • Poole
    • Omega 2.6
« Reply #3 on: 15 February 2014, 19:27:54 »
Ye the iffy start cleared straight away and has been perfect today. Will give the treatment a go and hopefully will do the trick.
Thanks for the help
  • Auckland
    • Mazda MPV
« Reply #4 on: 15 February 2014, 19:45:39 »
My 2.6 has been tapping for a few moments after a cold start for about 18 months.
I fitted new spark plugs a couple of weeks ago and found one loose plug :(
I haven't noticed the noise since...
« Reply #5 on: 15 February 2014, 19:56:05 »
Plugs had been in forever though iirc :-\ they start to come loose after 30-35k...
Leave them until the 80k interval that VX suggest, and you'll find them barely fingertight :y
« Last Edit: 15 February 2014, 19:57:45 by Taxi Al »
  • Auckland
    • Mazda MPV
« Reply #6 on: 15 February 2014, 20:09:34 »
They had been in for about 70k. (so pretty much backs up every comment made about the 80k service interval being an overoptimistic sales ploy.....)
I still think the plugs are worth checking, I hadn't considered a loose plug as being the source of the noise as all the experience on here points to lifters or manifold gaskets.
« Reply #7 on: 15 February 2014, 20:31:36 »
That it stops once the engine has settled immediately after starting does suggest a sticky lifter :y
« Reply #8 on: 16 February 2014, 09:44:09 »
Wynns can work wonders.
However, before putting it in, I'd change the oil, as it works better if you can leave it in for a few thousand.
« Reply #9 on: 16 February 2014, 09:46:31 »
Did an oil change last month but that didn't help it.  ....
Any thoughts ??
Ady
« Reply #10 on: 16 February 2014, 10:19:00 »
Good point, well presented  :-[
ajsphead
  • North Somerset
    • Omega 2.2 DTi estate
« Reply #11 on: 16 February 2014, 19:30:37 »
Had just the same problem. 2 oil flushes in 10K and GM oil and there's no sound at all now. Mind you I routinely throw a flush in at each oil change anyway.
Page created in 0.022 seconds with 20 queries.
