Author Topic: Water in boot under spare wheel.  (Read 1690 times)
Ady
  • Poole
    • Omega 2.6
« on: 16 February 2014, 12:40:08 »
After changing a light bulb I noticed that I have a small puddle under the spare wheel. Must of been there a while as has resulted in surface rust.
Anyone know where the water maybe getting in?
Thanks
Re: Water in boot under spare wheel.
« Reply #1 on: 16 February 2014, 12:45:28 »
Boot seal or light cluster seal...
Pop the light cluster out, any degrading of the seal should be obvious :y
Boot seal can only really be checked for condition :-\
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #2 on: 16 February 2014, 12:53:21 »
Or by shutting somebody in the boot  ;D ;D ;D :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 16 February 2014, 13:08:11 »
Ive found one where the seal was fine but the rubber adjusters where set wrong.  ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 16 February 2014, 14:35:19 »
Can also be a build up of condensation,due to rear vents being covered.
Hoof'land storeman.
« Reply #5 on: 16 February 2014, 18:43:14 »
On a saloon, its the lowest point, and where it tends to acculumate. No airflow to dry it out.
Every few months, I remove the spare, and clean mine out.
chrisgixer
« Reply #6 on: 17 February 2014, 09:12:29 »
Not encountered any of that in mine. :-\
But there was a post about leaking body work welds(?) in the boot shuts recently.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 17 February 2014, 17:25:36 »
Thought I would check mine  today and yes a small pool of water under the spare wheel.
« Reply #8 on: 18 February 2014, 01:12:05 »
Looked suspiciously like an accident repair :-\
