Pages: 1 [2] 3  All   Go Down
Author Topic: BT Powerline Adaptors  (Read 5406 times)
Re: BT Powerline Adaptors
« Reply #15 on: 17 February 2014, 19:06:11 »
Cheers all :)
A decent WiFi router is considerably more than these Power Plug network jobbies, hence going for these. All heavy media downloads will be going wired into the router, I just want a slightly improved connection for upstairs, bit of VPN, possible online games.
chrisgixer
« Reply #16 on: 17 February 2014, 19:37:18 »
Why not just get a bloody good wifi router?
In my case, because the ps3 wifi has failed, and the router is upstairs in the office.
...and no, I won't be buying a new ps4 or xbox1 instead.
Although we don't even have a bb connection ATM. ::)
« Reply #17 on: 18 February 2014, 08:09:47 »
yes - but some houses with thick Victorian walls just cannot allow a decent wifi signal to permeate.
Just re-engineered my daughters place to give better wifi signal at front of house - new latest Virgin wifi router installed - but to get signal to opposite end of house we previously had 25 metres of cable externally - now using powerline adaptors and stripped all cable out. Working fine. Wifi signal - no chance.
The wireless routers supplied FOC are rubbish, truely hopeless in my experience.
Even in the MIL's house where the internal walls are built using blocks made from Weldon spoil (e.g. iron ore), the wifi signal works well with a GOOD wireless router and hopeless with a naf Netgear free job.
Allenm
  • Milton Keynes
« Reply #18 on: 18 February 2014, 10:21:16 »
Have you got a make/model of a good wireless router?  My HH4 can only be seen in half the house and I'd rather not spend a day ripping floorboards up to run Cat5 round the place.
« Reply #19 on: 18 February 2014, 11:23:44 »
Also these HH5's I think have some kind of fibre unit built in? (as no box on the wall is needed now apparently)
So would that mean turning the HH5 into a switch? With a new WiFi router going off the HH?  :-\ :-\
« Reply #20 on: 18 February 2014, 11:46:20 »
I use an Asus AC66U dark Knight....wireless is pretty stunning on it!
The HH5 has no fibre port, it does have an integrated VDSL modem (as you are often supplied a seperate naff VDSL modem so it does away with this)
HH5 is supposed to have much improved wifi thanks to the triple antenna setup but, there internal so compromised somehwat (form over function).
« Last Edit: 18 February 2014, 11:48:55 by Marks DTM Calib »
« Reply #21 on: 18 February 2014, 11:48:59 »
« Reply #22 on: 18 February 2014, 11:57:18 »
Yep.
They do a version with built in modem for more money but, the wifi is not as good due to the internal antenna configuration
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #23 on: 18 February 2014, 12:11:59 »
The vigin super hub 2 works all round our house.
some people must live in bigger mansion, bigger than 3 bedrooms. :)
Hoof'land storeman.
« Reply #24 on: 18 February 2014, 12:17:05 »
Also a well respected performer (its a Netgear unit actualy), not nearly as good wifi (twin internal antennas) but above average.
Can you tell i spent weeks researching this before buying  ;D
biggriffin
« Reply #25 on: 18 February 2014, 12:24:00 »
I would never had guessed, i just go for free stuff, which is what i thought mr tunnie would do,or ask somebody at the rodeo were he works for a freebie.
for those thinking  rodeo=cowboys ;D
Hoof'land storeman.
« Reply #26 on: 18 February 2014, 12:26:59 »
He wont want to do that as the ones that Sky supply are utter rubbish and dont even have GigE ports  ;D ;D
I guess its in line with the 'reliable receiver' policy they clearly have  ;D ;D ;D :y
biggriffin
« Reply #27 on: 18 February 2014, 12:29:55 »
So as stated a 2bit cowboy company,.
wont have it as its over priced.and you can only watch one Chanel at a time..
rant over
Hoof'land storeman.
« Reply #28 on: 18 February 2014, 12:38:53 »
rant over
Eh? Current HD or plus boxes have twin tuners. Record something, watch something else. Or record 2 and watch on demand or previous recording.
« Reply #29 on: 18 February 2014, 12:41:14 »
tunnie - if you want to borrow a pair of powerline adapters (200Mbit or 500Mbit), let me know.. I'm not using my 200Mbit pair and I'm 'rarely' using the 500Mbit ones.
Pages: 1 [2] 3  All   Go Up
Page created in 0.032 seconds with 20 queries.
