Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: fuse jumper wire  (Read 20512 times)
darrenfos
  • eastleigh
    • omega elite manual
Re: fuse jumper wire
« Reply #30 on: 19 February 2014, 19:28:04 »
before i go any further can someone explain (cross section) as im a bit confused then i may be more helpfull.
omega is like marmite you know the rest
« Reply #31 on: 19 February 2014, 19:33:37 »
Diameter of conductor (copper wire)
darrenfos
  • eastleigh
« Reply #32 on: 19 February 2014, 19:39:28 »
right the copper wire is no more than 1mm thick, including the rubber its prob about 1.5mm, and the whole length of wire is just under a meter
« Reply #33 on: 19 February 2014, 19:39:34 »
thin wires can only carry small currents, thick ones carry more, so the cross section (thickness) of the wiring "may" give an indication of the sort of current it is expected to draw ....
« Reply #34 on: 19 February 2014, 19:51:19 »
Is it multistrands in each wire, or a single solid piece of copper. If former, is that 1mm for all the strands combined together?
darrenfos
  • eastleigh
« Reply #35 on: 19 February 2014, 19:52:24 »
its multi strands.
« Reply #36 on: 19 February 2014, 19:53:28 »
its multi strands.
OK, and that 1mm cross section is all strands combined together, rather than each strand being 1mm?
darrenfos
  • eastleigh
« Reply #37 on: 19 February 2014, 19:55:49 »
1 red + wire of multistrands and a earth of the size
« Reply #38 on: 19 February 2014, 20:22:23 »
Given your location, pop along to these people...
http://www.ultimateincar.co.uk/
Phone ahead, but I'm sure they will be able to help :-\
darrenfos
  • eastleigh
« Reply #39 on: 19 February 2014, 20:26:07 »
im thinking of just soldering it on to the cig lighter it does say 12v. so sod it
« Reply #40 on: 19 February 2014, 20:30:44 »
Worst case, the wiring melts and your car catches fire, then the insurers won't pay out because it's an unnapproved modification to the original design...
Still, not my car ::)
darrenfos
  • eastleigh
« Reply #41 on: 19 February 2014, 20:32:42 »
im just going on there basic instructions it say connect to 12v all i want to know is what amp fuse to put in between to be safe.
« Reply #42 on: 19 February 2014, 20:34:00 »
1 amp then :y
darrenfos
  • eastleigh
« Reply #43 on: 19 February 2014, 20:35:22 »
do you think putting a 20 amp fuse in the middle of the connections is ok
« Reply #44 on: 19 February 2014, 20:40:14 »
Er... no :o
Hence my previous two answers :-X
Pages: 1 2 [3] 4 5 6   Go Up
