Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: fuse jumper wire  (Read 20403 times)
Re: fuse jumper wire
« Reply #75 on: 20 February 2014, 20:56:48 »
Switch still requires two wires to work...
darrenfos
  • eastleigh
    • omega elite manual
« Reply #76 on: 20 February 2014, 20:58:19 »
it does have to wires a red and a black, red goes into control box and black is earth
omega is like marmite you know the rest
darrenfos
  • eastleigh
« Reply #77 on: 20 February 2014, 21:03:58 »
also the whole things works perfectly, as a front sensor's should but i wanted to make it safe with a fuse.
darrenfos
  • eastleigh
« Reply #78 on: 20 February 2014, 21:26:23 »
i cant remember who mentioned it but would a glass milli amp fuse holder be better and safer
AndyRoid
  • Hants
« Reply #79 on: 20 February 2014, 22:23:59 »
Those outside sensors need to be closer to the corner of the bumper if you want true corner protection.
darrenfos
  • eastleigh
« Reply #80 on: 20 February 2014, 22:29:55 »
if i put a 2 amp fuse between the positive and the cig lighter will it work or is that to low
AndyRoid
  • Hants
« Reply #81 on: 20 February 2014, 22:36:26 »
As it only draws 30mA, a 1amp fuse is too big really.
darrenfos
  • eastleigh
« Reply #82 on: 20 February 2014, 22:38:53 »
what about the small glass radio type ones
darrenfos
  • eastleigh
« Reply #83 on: 20 February 2014, 22:47:15 »
500mA Quickblow Glass 20mm Fuse from maplin that sounds better
« Reply #84 on: 21 February 2014, 14:31:53 »
Thats what I would use, going by the wire sizes you hinted at earlier (but never confirmed).
I'd also stay away from ciggy lighter, probably take it from the switched 12v going to radio instead :)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #85 on: 21 February 2014, 14:48:25 »
I reckon the unit will draw no more than 3 or 4 Watts, so I would go along with the 500mA Quick Blow as suggested already many a times.
If you want an in line glass fuse holder (minus the fuse) pm me your Addy and I'll post one, got loads kicking around.
darrenfos
  • eastleigh
« Reply #86 on: 21 February 2014, 14:55:55 »
All sorted now with glass fuse. Thanks for the offer zirk, and to all that helped me, just better to be safe.
darrenfos
  • eastleigh
« Reply #87 on: 21 February 2014, 17:31:37 »
One thing i can be proud of is that bumper full respray with cans
AndyRoid
  • Hants
« Reply #88 on: 21 February 2014, 20:31:21 »
The respray does look good from the pics, but you still have those corner sensors too far in towards the middle of the bumper (they need to be pretty much on the corner if you want them to work as intended).
« Reply #89 on: 21 February 2014, 23:17:28 »
Well that kept me entertained for a while, must pop in here more often......... :D :D :D
Pages: 1 2 3 4 5 [6]   Go Up
