Author Topic: CCR 2006 Cartridge Issues  (Read 4120 times)
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« on: 19 February 2014, 22:21:48 »
Hi guys my CCR 2006 disk changer cartridge won't lock in I can eject it with a great deal off fiddling but it won't accept the cartridge back and I can out it in and shut the outer door but the display just says magazine
Help
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: CCR 2006 Cartridge Issues
« Reply #1 on: 20 February 2014, 00:21:44 »
Sorry Sam, can't help, but that's a weird one!
Usually they won't eject but I don't recall any issues where the unit doesn't accept the cartridge?
pauls
  • By the sea minehead
    • Bmw x3
« Reply #2 on: 20 February 2014, 08:38:15 »
Try pulling fuse 12 for 1 hour. i find it seems to get rid of the gremlins.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 20 February 2014, 10:10:33 »
The Changer mechanism twists itself over time and eventually jamms up, which is the main reason that the cartridges cannot be ejected. Once a cartridge has been "persuaded" to come out, the mech is often still in a semi jammed state and will no longer allow a cartridge to be put back in.
Some have messed about with these and got them going again with a fair degree of success, but due to the age of them and the fact that parts dissappeared when Philips ceased trading back in 2000, its not something that we can support here at our repair centre any longer for this particular fault.
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #4 on: 20 February 2014, 13:40:41 »
It most likely is a mechanism fault.
If you can find a good working unit from another stereo or a CDC3 changer, you can swap over the lower half of the stereo. You MUST swap the vertical PCB in the changer portion, as that contains the config and coding.
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #5 on: 20 February 2014, 19:47:29 »
Mine did exactly tht the w/e when Mrs tried to use CD all i got was "magazine" , i kept trying and it eventualy worked perfectly and has kept going, i put it down to being cold and lack of use :-\  So give it another go Sam it will probably click in soon
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Sam Burton
    • Many
« Reply #6 on: 20 February 2014, 20:54:01 »
Right I've checked the magazine and works fine it won't latch in to the cradle but when it does it partially does and stills says magazine so it's not right will I have to dissemble the head unit to try a bodge or shall I just save the bother and look for a replacement
« Reply #7 on: 20 February 2014, 20:57:36 »
You can try a fix Sam http://www.omegaowners.com/forum/index.php?topic=90608.0
If no go I may be selling my CCR2006 and fitting the Alpine HU out of the MV6
