Pages: [1] 2 3  All   Go Down
Author Topic: fuse 29 problems ?  (Read 7691 times)
powerslinky
fuse 29 problems ?
« on: 25 February 2014, 17:39:47 »
Hi all
            any info on this little problem greatly received
Firstly as mention on my other thread front heated seats stopped working  :'(
Was advised to check various fuses as fuse 14   ( the one I thought was the front heated seats was ok)
checked all fuses out & Fuse 29 was blown . It was only a Red 10 where as my owners handbook says Yellow  20.
I replaced with a 20 & heated seats would now switch on  :) :)
after about a minute smoke started rising from the top of the climate panel directly above the drivers heated seat switch.
Switched off both seats & removed fuse , which was not blown.
Also noticed from the owners manual  that fuse 29 covers"airbag, cooling fan, courtesy lamp as well as heated seats " and my airbag
light has been on since I recently changed seats.  What & where  would be cooling fan & courtesy lamp so I can check if these are working
Could this have also caused the airbag light to stay on .   Problem with that is that I just removed the airbag bulb on Sunday as it was
driving me nuts as I have not been able to get a tech2 put on it to put it out  :( :(
TIA  :y
Ever Ready
  • Scotland
    • 2.2 CD Auto, Pug 308Hdi
Re: fuse 29 problems ?
« Reply #1 on: 25 February 2014, 18:06:08 »
Here is a copy from the online handbook/s
29 Cooling fan,
heated seats,
courtesy lamp,
airbag,
terminal 30:
constant current for
caravan/trailer
10 A
29 Cooling fan,
heated seats,
courtesy lamp,
airbags
10 A
Both versions show Fuse 29 as a 10A fuse
Hope that helps
An ounce of experience is worth more than a pound of enthusiasm.
« Reply #2 on: 25 February 2014, 18:26:31 »
GM's wiring diagrams show F29 is 10A
A fuse is there to protect the wiring, and thus a larger one should never, ever be put in. That's how fires start.
I assume it was all working before you buggered around swapping seats, so I'd be inclined to go back to that working configuration, and then work forward from there.
« Reply #3 on: 25 February 2014, 18:27:42 »
Although you may also need to remove the centre console components and inspect the wiring condition, following tuning it to channel smoke  :'(
powerslinky
« Reply #4 on: 25 February 2014, 18:29:05 »
29 Cooling fan,
heated seats,
courtesy lamp,
airbag,
terminal 30:
caravan/trailer
10 A
29 Cooling fan,
heated seats,
courtesy lamp,
airbags
10 A
Hope that helps
Bit of confusion here  . . . my owners handbook (edition  TS1433-2   June 2001) says :  20A
Marks DTM posted a comprehensive listing of cabin fuses for all cars back in October 2006 & shows a 30A
Really confused now .   Also  where it mentions "cooling fan"   would that be the ones in front of the rad then ?
powerslinky
« Reply #5 on: 25 February 2014, 18:32:46 »
Oops !   not looking good    eh    TB ? :'( :'( :'(
« Reply #6 on: 25 February 2014, 18:39:47 »
Well, as said, the fuse's only job is to protect the wiring. By effectively bypassing the fuse (by slapping a bigger one in), you are putting the wiring at risk, and the smoke you witnessed is likely to have been the wiring.
powerslinky
« Reply #7 on: 25 February 2014, 18:43:40 »
I appricate that TB . . . but looking it up in my owners book said a 20A  . . . thinking that an under rated fuse would blow.
Don't think there is any damage , there was no burning smell & only a slight sighting of smoke .
there is almost certainly a problem with the  heater pads , so can I unplug these from below the seats as I am not bothered about the heated seats ?
and then put a 10A back in to run the other bits ? :-\ :-\
« Last Edit: 25 February 2014, 18:45:39 by powerslinky »
« Reply #8 on: 25 February 2014, 18:46:30 »
I'd go back to where it was all working, esp as you've managed to bring on your airbag light, get it all working, then move forward to where you want to be.
« Reply #9 on: 25 February 2014, 18:47:53 »
Airbag light and non functioning heaters following seat swap. Anyone else hearing alarm bells?
They were the correct seats, weren't they?
powerslinky
« Reply #10 on: 25 February 2014, 18:51:57 »
Yep . . from  FL elite  in to FL MV6     got them from Albs .         We thought the airbag prob was to do with the child seat gizmo /sensor in the cabin light.
The airbag light on  was intermittant at first after swap then constant after a day or two
« Last Edit: 25 February 2014, 18:54:34 by powerslinky »
powerslinky
« Reply #11 on: 25 February 2014, 19:15:49 »
got me thinking now  TB  . . .   said seats came from an 02  3.2 Elite that Albs broke   . . . but could they have been incorrectly transplanted into that car?
How do I tell which era they are ?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #12 on: 25 February 2014, 19:32:50 »
A "reputed" autoelectrician did that to ex-BiL's car, having miswired the stereo... the next day all the smoke escaped from the wires...
« Reply #13 on: 25 February 2014, 19:34:16 »
Passenger seat fitted with transponder for child seat, flat yellow rectangular plug underneath said seat connected
« Reply #14 on: 25 February 2014, 19:35:37 »
That`s your SRS light problem. Guess you plugged in the yellow flat rectangular plug under passenger seat
Pages: [1] 2 3  All   Go Up
Page created in 0.24 seconds with 20 queries.
