Author Topic: Small Section Of loom and plug  (Read 2294 times)
amba
  • Medway towns
    • German V6
« on: 26 February 2014, 10:20:23 »
Constant issues with brake wear warning light,despite pads/discs being brand new so would like to resolve,as have traced fault to a corroded socket and damaged wiring.
I require the black circular socket that sits against the n/s front shock for the brake wear sensor plug and as musch of the wiring loom as can be cut before it goes into the wheel arch.
Also ideally the wear sensor to the brake pads(not worried if the ceramic part is broken) ,that way I can atleast cut and join the wires short term then have the correct intact socket for when I next replace front pads and can just plug new sensor wire in.
I like things working properly and warning display is annoying  :(
Martin_1962
Re: Small Section Of loom and plug
« Reply #1 on: 26 February 2014, 12:33:35 »
I will check mine
amba
  • Medway towns
    • German V6
« Reply #2 on: 26 February 2014, 13:06:47 »
I did drop you a PM Martin,although I  assumed you couldnt help,gratefull if you can though  :y
Martin_1962
« Reply #3 on: 26 February 2014, 19:07:56 »
Had another look it is the BWL cable.
Would £5 via paypal including postage be too much?
amba
  • Medway towns
    • German V6
« Reply #4 on: 26 February 2014, 19:09:20 »
Drop me a PM Martin so we can be sure its the right bit and then sort out.
Cheers
Andrew :y
