Author Topic: Bonnet cable  (Read 2431 times)
pauls
  • By the sea minehead
    • Bmw x3
Bonnet cable
« on: 26 February 2014, 16:52:05 »
Can anyone advise how to get the bonnet cable out of the adjustment box thingy...
I thought I would attempt to adjust my bonnet release cable as it took two to open it. Anyway I think I over did it because the cable has come undone from the spring release and I cant find it.
After speaking to ex taxi al I removed the spring hoping that the cable was still attached but it wasnt so I now dont know what to do because i cant find the cable end I think it has come out of the slam panel. The bonnet is know held down with a boot lace.
I knew I should have left well alone :'(
Re: Bonnet cable
« Reply #1 on: 26 February 2014, 16:59:26 »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Bonnet cable
« Reply #2 on: 26 February 2014, 17:19:17 »
The cover as in Marks 3rd pic doesn't exist on the Facelifts, having said that it is fairly straight forward, the spring is removed by unlocking the stay pin, turning the whole spring upwards at 90 degrees then lifting out, normally with the cable still attached, fitting is the reverse.
If the spring has come off, undo the cable adjustment clip, then wriggle the cable to locate under the slam panel, you can aid this by sticking your finger underneath through the square hole.  ;)
« Last Edit: 26 February 2014, 17:25:24 by zirk »
pauls
    • Bmw x3
Re: Bonnet cable
« Reply #3 on: 26 February 2014, 17:27:23 »
The cover as in Marks 3rd pic doesn't exist on the Facelifts, having said it is fairly straight forward, the spring is removed by unlocking the stay pin, turning the whole spring upwards at 90 degrees then lifting out, normally with the cable still attached, fitting is the reverse.
I have tried wiggling the cable with my figure in the hole but cannot see or feel anything. I think it has gone into that box at the back. I am a bit worried that if I undo the two nuts to much the box might fall off and there is no way to get your hand down the back of the slam panel with taking the rad out.
zirk
  • Epping Forest
Re: Bonnet cable
« Reply #4 on: 26 February 2014, 17:42:28 »
You dont  have to undo any nuts that hold the main plate.
Worse case, undo the Cable adjuster, as said, pull it out and back in again, your'll get the hang of it.
The hole underneath is before the Rad. ;)
« Last Edit: 26 February 2014, 17:45:23 by zirk »
pauls
    • Bmw x3
Re: Bonnet cable
« Reply #5 on: 26 February 2014, 17:57:30 »
Is it possible for it to come out of the slam panel because i cannot see or feel it or am i just been stupid.
zirk
  • Epping Forest
Re: Bonnet cable
« Reply #6 on: 26 February 2014, 18:15:56 »
Have you pulled the Cable out yet, is it complete, if so just feed it back in then push back towards the target area.
pauls
    • Bmw x3
Re: Bonnet cable
« Reply #7 on: 26 February 2014, 18:29:01 »
No I havnt pulled it all the way out. It to dark outside now so hopefully will have a go tomorrow.
cheers for advice.
zirk
  • Epping Forest
Re: Bonnet cable
« Reply #8 on: 26 February 2014, 18:33:09 »
cheers for advice.
:-X
pauls
    • Bmw x3
Re: Bonnet cable
« Reply #9 on: 27 February 2014, 10:00:53 »
I have managed to pull the cable out and fed it back in again I then undid the left screw at the back which allows the box/cover to drop away abit. This gave me access to reconnect the cable.
What i still cant figure out is how i slacken the cable off so i can adjust it. is it the other screw and do i turn it clock wise to slacken it off. I couldnt try this because I have to go to work.
zirk
  • Epping Forest
Re: Bonnet cable
« Reply #10 on: 27 February 2014, 10:11:59 »
Cable adjuster on the slam panel, near the Battery side, right hand side of Radiator.  ;)
Paul, unless Im missing something here, you dont need to touch the Bonnet Mech, its all done by removing the Spring and clipping it back in.
« Last Edit: 27 February 2014, 10:17:39 by zirk »
