Author Topic: Temp gauge  (Read 2155 times)
Ady
  • Poole
    • Omega 2.6
Temp gauge
« on: 28 February 2014, 13:10:28 »
I've noticed that my temp gauge is slow to move first thing.
After driving around for an hour, and driving it hard to encourage it rise it was still sat on the line between 80 and 0. It only rose to 90 once I was parked and let it idle for 5 mins.
I also went to my local GFS to buy some hydraulic vaulve treatment and when I opened the oil filler there was smoke coming out of it.
Is my car cooling itself properly or do I need a new thermostat?
Thanks Ady
2002 2.6 CDX
Re: Temp gauge
« Reply #1 on: 28 February 2014, 13:14:32 »
Sounds like you need a new stat :-\
Easy way to test... start car from cold and hold the top radiator hose...
If after ten minutes or so it is still luke warm then stat is toast. When working correctly, you should get a sudden rush of hot water as it opens :y
Re: Temp gauge
« Reply #2 on: 28 February 2014, 14:13:07 »
Smoke out of the filler or dipstick hole is usually a sign that the breather tubes need a cleanout :y
wiliferus
  • Reading
    • 2003 2.6 CDX Saloon Auto
Re: Temp gauge
« Reply #3 on: 02 March 2014, 09:41:37 »
Bit of a thread hijack, but mines the same so had diagnosed that the stat was knackered. Having looked at the 'How To' guide on here I'm a bit concerned it's beyond my (rather low) skill level!
How much should I expect to pay at an Indy for a stat change? Also, having looked at the work involved, it is worth getting them to do the cam gaskets as precautionary maintenance whilst the plenum and inlet is off?
Cheers
Re: Temp gauge
« Reply #4 on: 02 March 2014, 09:44:55 »
Whilst its *always" worthwhile to clean the breathers often, its normal to get smoke from the oil filler when the engine is hot.
Re: Temp gauge
« Reply #5 on: 02 March 2014, 09:48:30 »
Cheers
Its about £55 for a genuine part at trade price, worth having the transfer pipe as a spare for sake of a tenner, plus £20 of Red antifreeze.
If the camcover gaskets are OK, no need to change, esp as any indy will fit pattern ones that will last weeks, and besides, I doubt any indy (or dealer) could do the job satisfactorily.
wiliferus
  • Reading
Re: Temp gauge
« Reply #6 on: 02 March 2014, 10:14:06 »
Cheers
Ok, sounds like sensible advice ref the cam covers. What's the stat? Two hours labour?
Re: Temp gauge
« Reply #7 on: 02 March 2014, 21:07:50 »
Cheers
Always takes me longer, due to one bolt I always have trouble getting back in, yet everyone else seems to not have any real issue with it. So 2-3hrs sounds about right.
