Author Topic: OT - help needed for a stripped plug thread  (Read 686 times)
Bandit127
« on: 08 June 2008, 09:07:55 »
Hi All. As stated - OT because it refers to my mates Fireblade.
He has stripped no.4 plug thread (RHS viewed from the seat) and done a proper job - you can easily push the plug home by hand. The problem is that a conventional Helicoil repair needs the engine out. There's a beam accross the top of the engine that stops us being able to get a drill in there to drill the tap hole. Could probaby get something cobbled up to drive the tap with the space available though - about 1 1/2" above the head.
Engine out is £600!
Does anyone know of a thread repair kit that we could get in there with the engine in place? Like I said, there is about 1 1/2" above the head and the plug well is about 4" deep.
How about the Loctite "glue" kit - I am assuming that it would not cope with the temps and compression but I may be wrong.
The thread is 10mm (with what looks like 1.25mm pitch).
Thanks in advance.
Jim
Re: OT - help needed for a stripped plug thread
« Reply #1 on: 08 June 2008, 09:11:32 »
Sorry, other than helicoil, no other ideas that will be strong enough.  Std spark plug is 10x1.25 thread.
Moving to general chat as not Omega related.
« Reply #2 on: 08 June 2008, 12:26:52 »
You can get helicoil taps that dont require the hole drilling first...
