Author Topic: how to replace the information display to color information display(GPRC)  (Read 2694 times)
shadi
  • Amman/Jordan/Midel east
    • Omega/petrol 2.2/2003
how to replace the information display to color information display(GPRC) for omega petrol 2003 /2.2 automatik
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Color information display
« Reply #1 on: 01 March 2014, 16:34:30 »
How could I change information display to color information display GPRC/NCDR for omega 2003/petrol/2.2
If Im reading the question correctly, your asking how to change the GID for a CID but with reference to the GPRC, what ever one of them is? and the NCDR which I believe is the Single Din version as fitted to Astra's etc.
The common fitments on the Vauxhall Omegas were NCDC 2013/15 Double Din type, may be they used NCDR's in other Opel or GM models.
The easiet way would be to source a HU and matching CID Screen from a Donner Car and retro fit and adding the RGB Cable to suit, as the HU and Screens are Coded together.
As for the Vote side of things, no idea what that means but think I'll vote, 'SOME ONE HELP', just in case its a free All Expenses Paid holiday to Jordan  :y
Assuming you have an NCDC2013 or NCDC2015, depair it all with a Tech2, replace the screen, repair it all with a Tech2.
To depair, the original pairing code is needed.
« Reply #3 on: 01 March 2014, 19:08:15 »
As said on your other post, assuming its an NCDC201x stereo...
Depair, replace screen, re-pair.
Depair/re-pair needs tech2 and the original pairing code.
shadi
« Reply #4 on: 02 March 2014, 12:49:10 »
Hi Zirk
Its my fault to make you don't understand the question.
I have Opel omega 2003/petrol/2.2/4 doors.
In the car installed CCRT display and Half size screen.
I want to change this the above display to NCDx SERIES (CID) with full screen, full colour .
Note: can we install a full colour screen to the CCRT or not.
The hall idea to replace the half size screen to full colour screen and no problem if we can do that with out removing the CCRT .
shadi.omari@elico-jo.com
« Reply #5 on: 02 March 2014, 21:43:49 »
The colour screen will only work on the NCDC201x radios. It will NOT work with the CCRT2007/8 radio.
You will need to do some extra wiring, and adjust some existing wiring to fit an NCDC201x
shadi
« Reply #6 on: 03 March 2014, 07:38:02 »
Thanks very much for the Theboy & Zink.
I just wondering can I make these  extra wiring, and adjust some existing wiring to fit an NCDC201x or I need some one expert.
I am  Electrical power engineer so I have wiring background.
zirk
  • Epping Forest
« Reply #7 on: 03 March 2014, 11:54:13 »
Should be fine to do yourself, as said, some wiring mods / additions to make up and maybe get your hands on some additional plugs.
CCRT to NCDC with CID will require some additional wiring but it can be done, you cant operate the CCRT with the CID
The method I use is to get a connects 2 adaptor loom and make up the additional RGB connections here plus adjust the other wires
Admin note - Duplicate threads merged, posts pruned as required and placed in the Electrical section
