Pages: 1 [2] 3  All   Go Down
Author Topic: New Tyre recommendation  (Read 7258 times)
Re: New Tyre recommendation
« Reply #15 on: 02 March 2014, 18:59:51 »
Tunnie is the man to ask , he gets a lot of longevity from tyres  ;)
 ;D ;D ;D ;D
It's just unlike some I read the road ahead and don't have a ON/OFF button for the throttle  ::)
The way the OP posted sounds like they want cheap as possible, not a good idea on the Omega really. I'd highly rate Kumo's got their '31's' on the 2.2 and 39's(i think!) on the 3.0 Estate. They perform well, silent at speed, good grip in both wet and dry for the average driver and not mid-life crisis boy racer type, I'd go with these  :y
« Reply #16 on: 02 March 2014, 19:20:25 »
Try here ... just look at prices before decrying .. I was very surprised, they were £50 a tyre cheaper for me, and that was not on the budget range ... so the budget range might be worth your while ...
http://www.asdatyres.co.uk
They do a "Jinyu" at £50.00 !!! (although I've never heard of the brand !!)
« Last Edit: 02 March 2014, 19:22:35 by Entwood »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #17 on: 02 March 2014, 19:25:52 »
Goodyear Eagle F1 Asymmetric 2 235/45/17 .. Would recommend, Pricey but they seem like they are worth it so far  :y
« Reply #18 on: 02 March 2014, 21:15:29 »
I'm having variable results with these, which are likely to through the whole tyre threads into disarray  ::)
At the budget end, the Runway Enduros that Taxi Al mentioned or the Accelera Alphas are better than most on Omegas at the budget end.  Although wet weather grip is not great, they are not as dire as most budget offerings. Kumhos are OK, but more midrange, and lack feedback when they are about to kill you.
« Reply #19 on: 02 March 2014, 21:19:46 »
Not disputing you have doubts about these .. but then again, you do have a "particular" driving style that demands "particular" tyre characteristics .....  :)
Others may be able to survive quite adequately on a lesser tyre ....   :)
cd 2.2
« Reply #20 on: 02 March 2014, 21:20:20 »
Could do worse on a budget...
http://www.blackcircles.com/order/tyres/search
Runway Performance 926 £67.85, fitted...
Nothing special, but perfectly adequate for plodding around :-\
Found some even cheaper  :D http://www.tyre-shopper.co.uk/tyres/brand/westlake/westlake-sa05-xl/225-55WR16-99W-xl
« Reply #21 on: 02 March 2014, 21:51:39 »
You misunderstand. I have a set on the rear of one Omega, and its fine. Not superb, but pretty reasonable.
I have a set on the rear of the other, and they are disappointing.
Hence, the same tyre, effectively on the same car, but different results. Hence, potential for disarray in our joint attempt to catalogue tyres  :'(
chrisgixer
« Reply #22 on: 02 March 2014, 21:53:46 »
Guessing, but do you need mv6 lsc springs on the rear...?
« Reply #23 on: 02 March 2014, 21:57:08 »
Being lower/firmer, I'd expect the problematic car to provide better traction and resilience to sideways slip. Maybe its too firm  :-\
The car that works has standard non-self levelling springs, coupled with B4s.
chrisgixer
« Reply #24 on: 02 March 2014, 22:06:46 »
So, YES, then. :)
« Reply #25 on: 02 March 2014, 22:14:53 »
Not really though? Completely different size for starters  ???
chrisgixer
« Reply #26 on: 02 March 2014, 22:18:04 »
Ride height is different. So WILL be a different camber setting on the lower car. Mr TB admin sir is aware of the fix. Well, if he wasn't before, he is now.
As said a lot recently, the rear will not take more than 20mm lowering and remain in spec.
« Reply #27 on: 02 March 2014, 22:20:01 »
Plans afoot :)
Pooc77
  • Cambridgeshire
    • Omega 3.0 Mv6
« Reply #28 on: 03 March 2014, 11:54:16 »
Hi,
Kumho fine, but before you by cheaper read some ADAC tests!
You will find good tyers and see the rubbish too.
Do not forget you have to stop too!
« Reply #29 on: 03 March 2014, 13:16:26 »
Hi,
Without going off on one, tyre tests are largely irrelevant... Unless they're carried out using a similar chassis, so BMW 5 series/Merc E class. Any test using a fwd grotbox means nothing :y
Pages: 1 [2] 3  All   Go Up
