Author Topic: Aerial  (Read 6563 times)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
Aerial
« on: 02 March 2014, 18:56:21 »
Anyone any idea what kind of aerial this is and what it might have been used for?
https://www.dropbox.com/s/ll23krwt15u9942/Central%20Bedfordshire-20140301-00793.jpg
Re: Aerial
« Reply #1 on: 02 March 2014, 22:00:55 »
Pop the sunroof switch panel/motor cover off to see which side of the car it runs to, then have a rummage in the appropriate footwell, might find an identifiable plug on the end of it :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Aerial
« Reply #2 on: 02 March 2014, 23:38:09 »
Its a 1/4 Wave Whip on a M5 50 Ohm Base, by the lentgh of it I would say for UHF (Lower end) Radio Comms or could be Tertra (Dolphin or Airwave) but doesn't look long enough to me.
If you measured the whip length (from where the top of the plastic base meets the hinge part) to the top of the whip (the plastic cap pulls off) I could work out its frequency and give you a better idea what it was used for, assuming of course who ever installed it, knew what they where doing.  ;)
Re: Aerial
« Reply #3 on: 03 March 2014, 02:04:10 »
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Aerial
« Reply #4 on: 03 March 2014, 21:10:56 »
Zirk
The whip length is 10.50 cm.
zirk
  • Epping Forest
Re: Aerial
« Reply #5 on: 03 March 2014, 21:41:47 »
Zirk
No its not, I can tell its more than that just by looking at the picture.  ;)
zirk
  • Epping Forest
Re: Aerial
« Reply #6 on: 03 March 2014, 21:47:38 »
As in my earlier post, are you measuring it from the top of the plastic Base, ie where the plactic base meets the lower metal hinge base to the top of the whip, in other words the hinge lower part and the whip holder form part of the overall lenght.  ;)
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Aerial
« Reply #7 on: 03 March 2014, 22:06:47 »
I thought I might have had too much peach schnapps but have just measured it again with the top off to the top of the plastic cone (which unscrews) on the hinge. That is still 10.50?
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Aerial
« Reply #8 on: 03 March 2014, 22:15:43 »
I suppose what I would call the plastic cone at the base of the whip and attached to the hinge would add another 3 cm.
zirk
  • Epping Forest
Re: Aerial
« Reply #9 on: 04 March 2014, 10:29:59 »
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Aerial
« Reply #10 on: 04 March 2014, 12:18:57 »
Nice picture Zirk. I'll get back to you this evening. Thanks for being gentle with me.
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Aerial
« Reply #11 on: 04 March 2014, 18:42:29 »
13.50!
zirk
  • Epping Forest
Re: Aerial
« Reply #12 on: 05 March 2014, 21:25:19 »
Works out to around 472 Mhz, so just at the top end of the Public available UHF Spectrum, (419 - 474) so probably a PMR or PAMR use.
Once you go above 474 Mhz, it goes Militry or MOD untill you hit the TV DVB Band a bit futher up. There is also some old Goverment and or Broadcast fixed links channels in there but we wont go into that one. ;)
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Aerial
« Reply #13 on: 05 March 2014, 21:32:28 »
Thank you Zirk. I am in awe of your knowledge. I will let you know if I find out any more.
zirk
  • Epping Forest
Re: Aerial
« Reply #14 on: 05 March 2014, 21:42:59 »
Your welcome, bet you wished you never axked now.  ;D
