Author Topic: Changing HBV without draining coolant?  (Read 1360 times)
SMD
  • London
    • :( nowt
« on: 04 March 2014, 09:15:48 »
Can it be done or will it get too messy?
Thanks
Re: Changing HBV without draining coolant?
« Reply #1 on: 04 March 2014, 09:17:15 »
Thanks
You only lose a small amount of coolant when the HBV is removed.  :y  :y
chrisgixer
« Reply #2 on: 04 March 2014, 09:25:15 »
Yes, the water level only drops to the level of the leak. A severe hbv leak will see the coolant level drop to the bottom of coolant tank, as that's the height of the hbv. Hence that's where gm placed it, so the engine coolant doesn't empty avoiding the engine over heating if the hbv fails.
If the coolant level is still high in the bottle, it might be less messy to open the rad tap until the bottle is empty. There's certainly no need to empty the system completely though.
Some coolant will escape, inevitably, so a hose down with clean water after the work is done should minimise the never ending smell off coolant when the engine is hot.
SMD
  • London
    • :( nowt
« Reply #3 on: 04 March 2014, 09:39:29 »
Thanks dudes  :y
