Pages: 1 [2] 3  All   Go Down
Author Topic: Need new garage door.  (Read 3167 times)
Re: Need new garage door.
« Reply #15 on: 04 March 2014, 22:55:11 »
Just had an email quotation, remote controlled electric roller door. £1,600 pfffffff....siiiiigh.
Better get your name down on the OT list then  ::) ::) ::) ::)
chrisgixer
« Reply #16 on: 04 March 2014, 22:56:12 »
Think I'll fix the old one. :(
(WHEN it breaks again)
« Reply #17 on: 04 March 2014, 23:17:11 »
The one I linked to only needs an inch either side :y
chrisgixer
« Reply #18 on: 04 March 2014, 23:36:31 »
90mm I thought, looking at the chart. 125mm for a double.
Or bring the brackets in, but make the fixing wider. Narrows the opening, but who cares...?
« Reply #19 on: 04 March 2014, 23:45:12 »
Replace the existing frame with 4"x4" posts :y
« Reply #20 on: 05 March 2014, 07:58:56 »
Don't believe anyone who claims to be able to get a ceiling mounted opener to work with them. ::)
Little bro has, but they are a pain to set up, and the additional arm hangs low enough to cause scalp damage.
« Reply #21 on: 05 March 2014, 08:02:16 »
TB's garage has two or three bricks extra width either side of the door for instance. Mine has a 3 inch wooden frame, then half a brick. Not much room for gubbins on the end.
Its no wider, nothing was wider than the door frame. Height, esp if you want to electrify it, could be an issue.
« Reply #22 on: 05 March 2014, 08:19:50 »
The trouble with a roller shutter is that you have a large roller section at the top of the assembly so head room, particularly in domestic installs, is compromised.
chrisgixer
« Reply #23 on: 05 March 2014, 08:27:06 »
The height the roller door opens too may be very similar to the height of the up and over canopy door.
The difference being the new door will only be an inch wide strip across the opening I have to duck under. Where as the existing door is a 6 foot square area right over where I use the garage most. At the opening working on cars. I spend the entire time stooped over. ...it's not even useful when it rains as its wood and leaks through the slats.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #24 on: 05 March 2014, 09:06:34 »
I quite like the American roller doors which follow a track on the ceiling.  Easy to automate and no more problems with head clearance than a canopy type.
Are they available in the UK? :-\
    • Zafira Tourer & BMW 435i
« Reply #25 on: 05 March 2014, 09:14:05 »
£1.6k  :o :o
Sod that. It's only a door  ;D
« Reply #26 on: 05 March 2014, 09:16:47 »
Yes, they are 'up n over doors' from memory.
They do result in 2.2m of your ceiling being covered with the door open so can obscure lights in that area.
But yes, they are probably the better solution in reality.
Gaffers
« Reply #27 on: 05 March 2014, 09:18:39 »
I recall many of the ones I have seen have a light included in the motor body to help with that, but yes you are right, that's a lot of ceiling to cover.
« Reply #28 on: 05 March 2014, 09:47:44 »
£1.6k  :o :o
I don't doubt that you could by the door and DIY fit it in a couple of hours for half that. ::)
« Reply #29 on: 05 March 2014, 09:50:26 »
Yes, it does depend on having the height above the door frame. If you do have that height, though, it takes up less usable space than any other solution, IMHO.
Pages: 1 [2] 3  All   Go Up
