Author Topic: Coolant leakage...HBV or head to block mating... Anywhere else?  (Read 2997 times)
Re: Coolant leakage...HBV or head to block mating... Anywhere else?
« Reply #15 on: 09 March 2014, 12:30:22 »
Webby, remove plenum, but join the 2 pipes that go to throttle body.
Replace coolant tank cap with one with a valve in (mine survived the garage incident, it was blown into field behind!). With a bike pump, pressure it to about 8-10psi. You should be able to visually see leak - though to fully test HBV, disconnect vac pipe to it, check for leak, then suck hard on it, and check again (the valve can leak in either position).
« Reply #16 on: 09 March 2014, 12:34:48 »
Cap like this homemade bodge
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 09 March 2014, 17:57:11 »
Thanks TB. When I check i'll remove plenum and join the two pipes as you say..... but no need to make homemade cap as I pick up the pressure tester on Wednesday so will just use that!
nice bit on ingenuity though lol  :y
RIP Paul Lovejoy
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #18 on: 10 March 2014, 08:05:58 »
Nice roll of money you got there under the receipts  :P  :D :D :D
cd 2.2
« Reply #19 on: 11 March 2014, 01:29:28 »
Maybe it was needed to fund the home made pressure testing cap ?? Expensive business is research and development lol  :D
martin42
« Reply #20 on: 12 March 2014, 16:16:41 »
They were old samples  8) :-X
