Author Topic: Problem with 02 (pre-cat) sensor. Please help  (Read 7360 times)
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: Problem with 02 (pre-cat) sensor. Please help
« Reply #15 on: 15 October 2015, 22:37:57 »
Ok thanks I will try this tomorrow after work should get a chance to put on the ramp 👍
C20det
  • Belfast
    • 02 3.2 v6 Special
« Reply #16 on: 22 October 2015, 00:22:53 »
Still no luck tried erasing codes again but still getting same faults  :-\
C20det
  • Belfast
    • 02 3.2 v6 Special
« Reply #17 on: 22 October 2015, 00:24:17 »
Right guys, finally got round to getting a propper gm precat o2 sensor, it has been fitted but im still getting same symptoms which are very bad rough idle at startup when cold. And when its hot im getting an occasional missfire and car seems quite under powered. Ive checked all the wireing for burnt or cracked wires but it all seems fine. Im really at a loss now and any additional info would be greatly appreciated. Thanks to all again in advance. Dan
Did you get your problem sorted out ?
