Author Topic: Bloomin annoying reverse sensor  (Read 3718 times)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
Re: Bloomin annoying reverse sensor
« Reply #15 on: 13 March 2014, 12:24:57 »
Parking by touch is my speciality. Further investigation is obviously required. Thanks for your comments.
« Reply #16 on: 13 March 2014, 12:26:04 »
Doesn't answer the question though... what model is the Omega :-\
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #17 on: 13 March 2014, 12:28:00 »
2002 3.2 Elite Auto saloon?
« Reply #18 on: 13 March 2014, 12:35:47 »
Ah gotcha :y the reason for asking, is that factory installs are always in the same place, aftermarket ones could br anywhere ::)
The gubbins lives in the boot, just above the nearside wheel arch :y
Speaker cable runs up the C pillar and the speaker sits on the headlining about six inches back from the rear left hand corner of the sunroof :y
Have a rummage through the Electrical Help section, someone had the same problem just before Christmas... Shackeng or Entwood iirc :y
joshwyatt
  • Oxford
« Reply #19 on: 13 March 2014, 13:18:45 »
As Chris says, working parking sensors will have a faint ticking sound coming from them when they are activated. Activate the sensors, and listen to each in turn...whichever one is silent is the dead one.
« Reply #20 on: 13 March 2014, 13:36:24 »
remove the test resistor fromm the small plug by the rear left light cluster .. looks like a stanadrd fuse but has a resistor instead. Then select ignition on/reverse .. the system is now in self test mode and the bleeps will tell you which sensor has failed .. :)
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1279621948/30
post #30
« Last Edit: 13 March 2014, 13:38:31 by Entwood »
« Reply #21 on: 13 March 2014, 13:38:09 »
Sorry ::)
Got muddled by...
Mine are currently silent when reversing!
Jasons issue is a duff sensor, test as per Chris or Entwoods method :y
Lagondanets issue is either a duff speaker or knackered control box/wiring :y
« Last Edit: 13 March 2014, 13:42:43 by Taxi Al »
« Reply #22 on: 13 March 2014, 13:38:52 »
Only bleeps it the speaker works... :y
very true ... :)
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #23 on: 13 March 2014, 14:36:31 »
Thanks. I'll check.
Crazycarzowner
« Reply #24 on: 13 March 2014, 15:24:15 »
Wish mine was!  :D ;D ???
Page created in 0.022 seconds with 20 queries.
