Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Rocker cover gasket  (Read 13135 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Rocker cover gasket
« Reply #30 on: 14 March 2014, 11:46:21 »
2002. only had it last Saturday. I e-mailed the guy i bought it off last night. He's Romanian so was hard to understand but when i took the car for a test drive last week i'm sure he mentioned the rocker gaskets had been done about a month ago. He replied this morning and confirmed he did so it's got to be the rocker gaskets, probably not done correctly !!
quite possibly, bet its from the half moons. prob didnt put any sealant in the corners.  :)
dave irmscher
  • staffordshire
    • Omega MV6 IRMSCHER
« Reply #31 on: 14 March 2014, 11:53:00 »
Would it be possible to salvage the gaskets, you know, remove the rocker covers and re-fit the gaskets correctly with sealant with them only being done a month ago or do they have ti be renewed once the covers are removed?
The Red Baron
« Reply #32 on: 14 March 2014, 11:59:39 »
should be able to re-use as long as they are not mangled, i do have a good set here, if i can find them. lol.
 ;D
dave irmscher
  • staffordshire
« Reply #33 on: 14 March 2014, 12:08:31 »
What sealant are you supposed to use then. I have a tube of normal black DIY sealant in my garage, will that suffice ??????  :-\
The Red Baron
« Reply #34 on: 14 March 2014, 12:12:05 »
not really, need the black vauxhall goo.  :y
the stuff you have will not be oil tollerant.  ;)
dave irmscher
  • staffordshire
« Reply #35 on: 14 March 2014, 12:14:47 »
ok. Where would i get it from ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #36 on: 14 March 2014, 12:19:41 »
A tube of this
Black sealant for cam covers              # 90485251
Less then a fiver from all Vauxhall parts departments  :y
The Red Baron
« Reply #37 on: 14 March 2014, 12:19:58 »
vauxhall dealer tbh. part no...90485251
bugger, you beat me to it tigers.  :D
dave irmscher
  • staffordshire
« Reply #38 on: 14 March 2014, 12:52:32 »
Right, just phoned my local Vx dealer who has the said goo in stock. So tomorrow i will try to salvage the gaskets that are in place and let you know how it goes  :-\
And thanks for your offer of help, most appreciated mukka  :y
The Red Baron
« Reply #39 on: 14 March 2014, 12:54:58 »
do have a read of the how to though first, tricky job but sure you will be ok.
give us a shout if you hit any problems.
jon.  :y
dave irmscher
  • staffordshire
« Reply #40 on: 14 March 2014, 13:04:01 »
To be honest Jon it's all i have read up on all week  :o But yes i'll get stuck in tomorrow and if i hit a brick wall i'll let you know :y
Dave
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #41 on: 14 March 2014, 13:21:52 »
As Jon says any problems just post on here  :y
I'm sure somebody will be able to take the pish  have a good laugh  help you out   ;D ;D ;D
Just in case you need them
You may need two of these .......   2.6/3.2 Cam cover seals      # 90511541
Have fun  :D
« Reply #42 on: 14 March 2014, 13:46:31 »
Dave
when you do the passenger side gasket, tie the loom up out of the way, tie it to the bonnet strut  :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #43 on: 14 March 2014, 14:09:29 »
And yes 8Nm is important.
TuBy's new whipping boy.
dave irmscher
  • staffordshire
« Reply #44 on: 14 March 2014, 16:34:03 »
Got home from work and had a feel around the rocker covers and it'quiet damp with oil. I also noticed that whoever did the job previously has fitted one incorrect bolt on one of the rocker covers, it has an alan key head !! Is it possible to buy replacement rocker cover bolts, the torx ones ? :'(
Pages: 1 2 [3] 4 5 6   Go Up
