Author Topic: thermostat  (Read 3754 times)
tidla
  • solihull
thermostat
« on: 21 March 2014, 10:44:09 »
Doing a bit of running around last night when the temp gauge red lined. Popped the bonnet and had a quick check in the dark, aux belt in tact and coolant full. Hoses didnt seem too hot so gingerly tried to get home but the expansion cap wasnt having any of it.
Went back to it today and topped up with half a litre of coolant and all seems well.
Im guessing the thermostat threw a wobbly and stuck.
Changed it a couple of years ago due to a leak around the mating flange and fitted a Q H thermostat on its own.
Hate doing jobs twice, (original obviously lasted 10 years+, so what brand should i fit / complete housing??
thanks
Re: thermostat
« Reply #1 on: 21 March 2014, 10:45:38 »
I only use GM. About £55 on Trade, last one I bought.
Re: thermostat
« Reply #2 on: 21 March 2014, 11:17:57 »
Re: thermostat
« Reply #3 on: 21 March 2014, 11:26:05 »
It's also possible that the water pump has shed its' impeller, of course. :y
tidla
  • solihull
Re: thermostat
« Reply #4 on: 21 March 2014, 12:17:31 »
It had a new one a few years back at timing belt time. The return hose kicks out coolant when revved so guessing the pumps doing its job.
sjr47
Re: thermostat
« Reply #5 on: 21 March 2014, 12:33:02 »
Used a Wahler one on my 2.6 15 months ago all OK only problem being the flange is thinner than original so need to cut down or obtain shorter bolts .http://www.bestpartstore.co.uk/opel-omega/omega-b-25_-26_-27/3861/10195- £29 although postage is pricey from there.
« Last Edit: 21 March 2014, 12:35:03 by sjr47 »
Re: thermostat
« Reply #6 on: 21 March 2014, 12:57:23 »
No such issues with the one I linked to :y
tidla
  • solihull
Re: thermostat
« Reply #7 on: 26 March 2014, 10:27:39 »
No joy with a transfer tube. On back order with gm till, who knows. #
Ideas??
Re: thermostat
« Reply #8 on: 26 March 2014, 12:08:05 »
Not cheapest, but the place I linked to for thermostat sell them :y
http://www.ebay.com/itm/Cadillac-Catera-CTS-Saturn-Vue-L-series-Thermostat-Housing-Tube-90411629-/200750794653?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2ebdae079d
About £50 delivered, but available from stock rather than an unknown waiting time...
« Last Edit: 26 March 2014, 12:11:36 by Taxi Al »
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Re: thermostat
« Reply #9 on: 26 March 2014, 12:16:55 »
Have you checked the fuse for the main fan in the engine bay, mine went and caused an overheat.
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
Re: thermostat
« Reply #10 on: 26 March 2014, 19:54:25 »
Al i noticed you suggested buying transfer pipe as well as thermostat, just ordered stat from vx along with two pipe seals and actual stat seal, should i have got pipe aswell?
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: thermostat
« Reply #11 on: 26 March 2014, 19:55:16 »
Yup ::) see my last on your running temp thread :y
Incidentally, new transfer pipe should include o rings :y
Toledodude1973
  • IPSWICH U.K.
Re: thermostat
« Reply #12 on: 26 March 2014, 20:01:27 »
The rings are ordered so might have spare couple of rings ,will order pipe tomorrow,any idea on part no.
Re: thermostat
« Reply #13 on: 26 March 2014, 20:05:14 »
90411629 :y
Toledodude1973
  • IPSWICH U.K.
Re: thermostat
« Reply #14 on: 26 March 2014, 20:09:55 »
That is service , thank you AL :y :y :y
