Author Topic: Cheapest way to get freeview?  (Read 3433 times)
theolodian
  • I need a new avatar.
« on: 10 June 2008, 18:24:52 »
We seem to only have one outlet for the roof aerial in the house.  We want to have a small TV in the bedroom.  What is the cheapest workable way to have freeview?  Do rabbit ears, etc. work for freeview?  Amplified aerial?  Get a guy in to snake a cable into the loft and tie into the roof aerial?
Freeview doesn't work that well around here, most of the channels drop off a lot of the time, so I don't want to spend more than necessary to get something that doesn't work very well in the first place.
TIA!
Re: Cheapest way to get freeview?
« Reply #1 on: 10 June 2008, 18:42:28 »
TIA!
The fact that I know you have trouble anyway, all the mickey mouse stuff will be worse :(
theolodian
« Reply #2 on: 10 June 2008, 19:04:10 »
TIA!
Either the transmitter works or it doesn't.  Seems to drop out regularly.  Analog always works, as well as BBC1 and 2 on freeview.  The rest of it is a cr@pshoot.
stuart30
« Reply #3 on: 10 June 2008, 19:11:29 »
Had a similar problem in my old house due to weak signal...spent £180 having a loft Ariel supposedly especially for freeview and low and behold it was utterly useless and that's with it being boosted by the fitter.
Have you considered a dish...several free to view channels without subs. :y
I use one of these at work as the signal here isnt much cope...works pretty good so might be worth buying one and giving it a go.
http://www.argos.co.uk/static/Product/partNumber/5344204/Trail/searchtext%3EAERIEL.htm
theolodian
« Reply #4 on: 10 June 2008, 19:18:09 »
We don't have permission to install a dish.  Yeah, I may give one of those amplified thingies a shot.
carlos_fandango
  • Stoke On Trent
« Reply #5 on: 10 June 2008, 19:54:33 »
We have a freeview box, a tv with a portable aerial (looks like a small version of a roof aerial) and a £5 booster box.
Works great get all the channels.
AERIAL to BOOSTER to FREEVIEW to SCART to TV
Carlos
carlos_fandango
  • Stoke On Trent
« Reply #6 on: 10 June 2008, 19:55:23 »
Do have to put the aerial quite high up in the room though, ours is hanging over the curtain rail in the bedroom.
Martin_1962
« Reply #7 on: 10 June 2008, 21:21:08 »
Here goes.
1) Check the cables, possibly recable with CT100, check the aerial, how old, how big ect - a picture may help
2) Get a decent box, PVRs are usually better than £20 noddy boxes.
3) Daisy chain to upstairs, my cable route is
Aerial->amp
PSU->TV->Twin->BT Vision->Beta VCR
-------> back up stairs
->Pace DTVA
Yes I do have 2 PVRs, 1 box and an IDTV
STMO123
« Reply #8 on: 10 June 2008, 21:26:02 »
If you are in an area where the signal strength is weak Theo, then you're likely to be fooked. I've tried everything for my poor old mum in Liverpool, all to no avail. A chap who came out to have a look quite honestly told me I was wasting my time.
theolodian
« Reply #9 on: 10 June 2008, 21:57:06 »
We get freeview from the existing building aerial directly through the TV or BT Vision.  However, the transmitter seems to drop out regularly.  Not looking to fix that, just to see if we can get freeview in the bedroom where there is no outlet for the building aerial.  We rent, so can't do a dish or other major work - and not worth too much trouble since the transmitter is flaky.
« Reply #10 on: 10 June 2008, 21:59:04 »
Doubt the transmitter is dropping often, I'd suggest weak signal...
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #11 on: 10 June 2008, 22:00:10 »
if your pc is in the room
http://zattoo.com/
theolodian
« Reply #12 on: 10 June 2008, 22:07:17 »
Often it is fine, then all but a few channels drop out.  We are supposed to get freeview here, but the neighbors have Sky so no idea if the signal is any good for them.
Danny
  • Wigan, Greater Manchester
« Reply #13 on: 10 June 2008, 22:07:27 »
freeview boxes are dirt cheap, have a nosey through your yellow pages for a company that will fit an extra roof aerial onto your house
thats what i've done, aerial was about £50 (held onto the chimney properly and not drilled into the brickwork!), freeview box was lifted from my mates when he got sent down, to cover an outstanding debt
theolodian
« Reply #14 on: 10 June 2008, 22:07:54 »
http://zattoo.com/
No it isn't, and the Wifi is yet another problem at the minute!
