Author Topic: Best potion for wheel cleaning.  (Read 7785 times)
Re: Best potion for wheel cleaning.
« Reply #15 on: 23 March 2014, 21:00:45 »
wheels are painted with the same metallic paint and laquer (clearcoat) .. so whatever is harmful for your car paint is valid also for wheels..
problem with brake dust is when its mixed up with mud and let for long, it sticks to laquer surface .. you can always use paint protector wax (used on car paint) to clean them without harming the surface.. first wash, then apply one layer and buff with a soft towel once in a month.. they wil have less dust than before..
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #16 on: 23 March 2014, 21:24:21 »
I only use AG wheel cleaner, its a 1 hit type of thing where you spray onto the wheel, let it dwell for about 5 mins and then rinse off..... gets shut of brake dust too :)
D.I.L.L.I.G.A.F...
chrisgixer
« Reply #17 on: 23 March 2014, 21:27:08 »
Fair enough, but body paint doesn't get covered in brake dust..?
« Reply #18 on: 23 March 2014, 21:29:06 »
The wheels do get alot hotter though :-\
chrisgixer
« Reply #19 on: 23 March 2014, 21:32:37 »
 Yes heat transfer from the brakes breaks. ::)
« Reply #20 on: 23 March 2014, 21:35:28 »
how about bird poo  ;D
problem is brake dust is let there for a long time :-\  and also they are hot when they hit  the surface of wheel :(
« Last Edit: 23 March 2014, 21:37:45 by cem »
chrisgixer
« Reply #21 on: 23 March 2014, 21:38:11 »
Right, so what to use? Kosovans have already washed the wheels, with similar methods as the rest of the car, plus their wheel cleaner, yet the brake dust remains.
« Reply #22 on: 23 March 2014, 21:40:04 »
if Kosos have cleaned wheels, but unable to move brake dust, you're probably in realms of refurb
minifreek
  • Wigan
« Reply #23 on: 23 March 2014, 21:43:12 »
If there is brake dust remaining after a wash, you could get a product called Iron-X that will remove 99% of the brake dust, regardless as to whether it is embedded into the paint/lacquer on the wheel or not...
D.I.L.L.I.G.A.F...
chrisgixer
« Reply #24 on: 23 March 2014, 21:43:29 »
Already done. As said in post 1. Outside surface is clean. The inner surface of the wheel rim is still peppered.
May I refer Mr Admin Sir to post 1.
chrisgixer
« Reply #25 on: 23 March 2014, 21:45:43 »
...and bird poo comes off with basic washing. In case the body shop specialist hasn't noticed.
« Reply #26 on: 23 March 2014, 21:46:09 »
paste with wax..  but if your car washed weekly at least ,you wont have that dust problem or you are making very high mileage daily :-\
« Reply #27 on: 23 March 2014, 21:48:23 »
I can recommend a solution ..
buy some scratch resistant laquer , sand the surface of wheels with 500 wet than let them sprayed with 6-7 coats ..
then you can polish/paste them even everyday ;D
« Reply #28 on: 23 March 2014, 21:49:29 »
seriously wax prevent brake dust setting on them at least minimizes
I guess refurbish centers dont use the most expensive and hard laquer  just for wheels..
« Last Edit: 23 March 2014, 21:51:11 by cem »
chrisgixer
« Reply #29 on: 23 March 2014, 21:51:15 »
Weekly? In winter? With floods? It hasn't been washed for weeks.
So, cem, what to use? Dtm's RobG's and Minifreeks suggestions all look viable. :)
Pages: 1 [2] 3 4  All   Go Up
