Author Topic: interior light stays on all the time  (Read 7498 times)
Re: interior light stays on all the time
« Reply #15 on: 02 April 2014, 23:24:21 »
Hi there if i take it out and shut the door it stil stays on. That really doesn't sound good then does it thanks again  :)
Try that again and double lock the door, so that the timer delay switches off... it should dim down within a minute of the second press of the remote...
chuftsmv6
  • stoke on trent
    • omega mv6 2jz and audi s3
« Reply #16 on: 02 April 2014, 23:28:45 »
Hi i tried that if i remember correctly all my little window light switches went out but the light stayed on its a little strange  :)
i just wanted to add all my door puddle lights all go on and off as normal when i open and close the doors if that helps  :)
« Last Edit: 02 April 2014, 23:31:09 by chuftsmv6 »
« Reply #17 on: 02 April 2014, 23:33:46 »
Apart from the loom, that only leaves the headlight switch, door switch and the light unit, all easy enough to change :y
When acquiring the new light unit, it must be identical to the old one as ones with sensors/built in microphones aren't interchangeable with ones that don't have them :y
chuftsmv6
  • stoke on trent
« Reply #18 on: 02 April 2014, 23:38:08 »
Thanks again you have been a massive help i will have a good look at the weekend Il get the code off my light unit and try to match em up thanks again  :)
chuftsmv6
  • stoke on trent
« Reply #19 on: 21 April 2014, 21:16:03 »
hi there sorry for the late reply i couldnt get any time on the car for a while, i finally found the problem it was actually the headlight switch unit that was faulty thanks again for all your help :)
