Author Topic: Hbv  (Read 5261 times)
chrisgixer
Re: Hbv
« Reply #15 on: 27 March 2014, 13:03:08 »
Thanks Chris I think that the air con is working ok I am trying to confirm whether it is the HBV leaking before stripping out scuttle or inlet and plenum as suggested by Darth.
Yes. In order to confirm the hbv leak is leaking, you need to;
1) find it
2) see if it leaks
3) if confirmed leaking, replace it.
1) follow the vac pipe from the heater pipes in bulkhead. This leads to the hbv hopefully.
2) to test the hbv you need the engine running, which means leaving the engine parts in place, and cycling the cc from hi to lo with hand/s on the hbv each time to see/feel if it leaks.
3) once confirmed as leaking, Daz suggests removing the plenum as said. I prefer to remove the scuttle and re seal it, insuring its water tight and doesn't drip on your coil pacs. Marks Dtm suggests replacement by removing nothing but the hbv. Choice is yours.
The vac pipe from heater matrix pipes on bulk head attaches to the top of the hbv and the cc uses this via vacuum to switch the coolant flow away from the heater matrix via the hbv. This is the sole purpose of the hbv. With cc on lo the coolant flows one way through the hbv. With cc set to hi through the other coolant way in the hbv. So by switching the cc from hi to lo you are able to test both the water "ways" of the hbv.
Just to clarify ;)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Hbv
« Reply #16 on: 27 March 2014, 13:11:25 »
Hello Al No I dont have water in the footwell.
Re: Hbv
« Reply #17 on: 27 March 2014, 13:27:36 »
Ah... Ok, earlier post suggested that you might have had :-\
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Hbv
« Reply #18 on: 27 March 2014, 14:18:47 »
Just run up to temp Air con HI Low no water under car How is it possible to get your hand under the hbv I assume that the scuttle has to come off,
chrisgixer
Re: Hbv
« Reply #19 on: 27 March 2014, 15:03:09 »
ahem.....
....FOLLOW THE VAC PIPE
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Hbv
« Reply #20 on: 27 March 2014, 15:07:17 »
Please can you educate me - where is the vacuum generated for the HBV, and why?
Ron.
chrisgixer
Re: Hbv
« Reply #21 on: 27 March 2014, 15:18:32 »
That wont help you find it.
There,s plenty of info on here about it via the search button.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Hbv
« Reply #22 on: 27 March 2014, 15:23:16 »
Hello Chris I have found it ok but my hands are quite small and I cant get my hand under it
