Pages: 1 [2] 3  All   Go Down
Author Topic: How accurate is that Scan My Opel app ?  (Read 10013 times)
Re: How accurate is that Scan My Opel app ?
« Reply #15 on: 27 March 2014, 13:36:27 »
Which interface adaptor do you use?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #17 on: 27 March 2014, 19:02:47 »
Looks like there may be a fault somewhere, mine shows 0 RPM in the engine module whilst running but shows fine when in the AT module.
TuBy's new whipping boy.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #18 on: 27 March 2014, 20:21:28 »
Just a thought, There is a possibility there may be a slight leak around the manifolds or even where the cat section joins the single outlet custom exhaust, Would these possibly be causing those fuel trim / O2 sensor error codes ?
« Reply #19 on: 28 March 2014, 08:14:50 »
Post #10  :y
http://www.amazon.co.uk/dp/B009NPAORC/ref=cm_sw_r_udp_awd_A31mtb0N431B7
Sorry missed it, cheers for link. Good price will get one of those  :y
« Reply #20 on: 28 March 2014, 19:15:23 »
I think this app is still very much work in progress, and has lots of flaws still.
Accept that its currently barely functional, but hopefully with the potential to be better in the future, and you won't be disappointed :)
Additionally, some of the poorer (ie, the cheap Chinese tat clones) implementations of the hardware are also a bit flakey (and that's being kind!).
  • Auckland
    • Mazda MPV
« Reply #21 on: 28 March 2014, 20:26:13 »
I have noticed that mine seems to read zero RPM from the engine ECU but the correct RPM from the gearbox ECU  ???
There was rapid development a few months ago but I haven't seen any progress that benefits the Omega recently :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #22 on: 28 March 2014, 20:31:29 »
Thats good to know, I'M NOT ALONE Thank goodness  :D ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #23 on: 28 March 2014, 21:25:14 »
Thought I'd try it on the tablet.
I cleared these codes to see which came back.. No idea why some are red, orange, green..  :-\
These are after clearing few days later...
Along with live data (at idle)
I haven't a clue what any (well most of) that livedata means..
I wish i knew how to read/understand this live data, From the live date in the screen snap pictures above does everything seem OK?.. I just wan't to put my mind at rest.. Car is running fine, Power is there when needed, Idles fine, Starts first time.. Don't use it every day so it does stand for a few day up to a week sometimes... But when I do use it its usually for 100+ miles..
  • Auckland
    • Mazda MPV
« Reply #24 on: 28 March 2014, 22:12:26 »
I suspect that a number of the items that are either on/off 0/1 active/inactive are reading the wrong way round. Variables (numbers) seem to be more reliable (ignoring engine RPM ::))
I don't imagine that either of your engine warning lights are lit but there is a line reading "Malfunction indicator" "on".
I have noticed that the "sport button" is normally "active" on mine but "inactive" when I press it ???
The developer does ask for people to send him logs if they notice a problem so he can improve the software. I haven't (yet) because I haven't worked out how to do it  :-[
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #25 on: 28 March 2014, 22:40:10 »
There are 3 bulbs (EML, Main Beam, Right Side Background Illumination) that i'm aware of that are fused/missing, Trying to find time to take the dash out to do this..there's also a rattling sound behind there which does sound like a small glass type bulb that's causing this only now and then on a rough surface road...
  • Auckland
    • Mazda MPV
« Reply #26 on: 28 March 2014, 22:44:54 »
With two flat bladed instruments (not too sharp) (to pop the centre air vents out) and a Philips screwdriver you can have the instrument cluster out in about 5 minutes.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #27 on: 11 April 2014, 18:06:54 »
Thought I'd hook it up again today, Some seem to have cleared them selfs too  :y
This one below was after clearing codes...
Presuming this is accurate this is good news i take it  :)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #28 on: 11 April 2014, 19:36:21 »
See what it throws up next week  :y
« Reply #29 on: 12 April 2014, 10:07:17 »
Why don't you put the bulb back in, and have a clear car?
Pages: 1 [2] 3  All   Go Up
