Author Topic: Oil leak  (Read 9392 times)
Gordon1066
  • upper halling kent uk
    • Omega Estate
Oil leak
« on: 28 March 2014, 16:47:08 »
I have an 02 2.2 estate that has developed an oil leak at the front end. It appears to be behind the bottom engine pulley, could it be a crankshaft oil seal that has gone? If so is it hard to replace?
Cheers
Gordon1966
flyer 0712
Re: Oil leak
« Reply #1 on: 28 March 2014, 23:19:31 »
Hi matey..if you post your question in the help department then more members will see it and help you  :y :y
cd 2.2
Re: Oil leak
« Reply #2 on: 29 March 2014, 02:03:29 »
Going to presume you are talking about a 2.2 petrol .... If it is, they tend to leak (every one I've seen recently) on the front camshaft bridges just under the front of the rocker cover! Easy fix if it's not the camshaft seals themselves! Basicly if you take of the front belt cover (big black plastic bit, tons easier to remove with the alternator belt removed) you will most likely find that the oil is leaking at the very top around the camshaft seals!
If this is the case, to resolve the issue is fairly straight forward. Refit a new gasket, seal around the very front and very rear cam bridges with something like Loctite 5910 taking care not to block any oilways! Re-fit your top cover with the new gasket installed ... Bob's you aunty It SHOULD stop leaking!
Main symptom of a leak from here is a misting of oil appearing on the underbody plastic panel that sits below the radiator, usually around the bottom pulley area! All of the timing belt area may also have oil present underneath the cover .... It does seem to get everywhere  ::)
Hope this helps you
Graham
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: Oil leak
« Reply #3 on: 29 March 2014, 22:55:33 »
Hello,welcome to the Forum :y
Re: Oil leak
« Reply #4 on: 30 March 2014, 00:14:08 »
Welcome to OOF mate  :y
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: Oil leak
« Reply #5 on: 30 March 2014, 13:35:53 »
Welcome aboard, Gordon!  :)
C20NE - X25XE
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: Oil leak
« Reply #6 on: 30 March 2014, 15:37:40 »
Hiya welcome to the forum :y
Kendo1690
  • Liverpool
    • 52 3.2 Elite,08 Zafira150
Re: Oil leak
« Reply #7 on: 31 March 2014, 11:30:38 »
Hello and welcome to OOF, :y
slowboy
  • lode
Re: Oil leak
« Reply #8 on: 31 March 2014, 15:50:21 »
welcome to oof :y
Pooc77
  • Cambridgeshire
    • Omega 3.0 Mv6
Re: Oil leak
« Reply #9 on: 01 April 2014, 19:58:34 »
Welcome here!
x25dt
  • Portugal
Re: Oil leak
« Reply #10 on: 02 April 2014, 18:17:32 »
Welcome to oof :y
