Author Topic: Wishbones  (Read 1387 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Wishbones
« on: 31 March 2014, 20:19:16 »
     Went down to Bristol to see RobG today and my Dti still has a knock when i put on the brakes, i fitted new wishbones (flea bay £50 a set (i know)) new drop links fitted and a tracking check done(not at WIM) then after MoT (clean sheet) car pulls to left a bit but not all the time and a knock when brakes go on from both sides, other week i put a new steering idler on and no change.
     Yesterday had front wheels off and could not find anything amiss. so put a bar up between front bush and give it a little lever, now correct me here but i don't think there should be any movment front to back, and before you say anything the bolts and nuts are done up
     I have a set of poly bushes in the garage and think they will have to go on. If it is the bushes they lasted 2 months or less >:(
Re: Wishbones
« Reply #1 on: 31 March 2014, 20:44:34 »
Poly bushes every time imho...
Where did you buy them/what brand :-\
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Wishbones
« Reply #2 on: 31 March 2014, 20:57:13 »
Will have to go back and look at my pay-pal and find out :-\
Re: Wishbones
« Reply #3 on: 31 March 2014, 21:08:25 »
These are the only people I buy cheap wishbones/track rods from...
http://members.ebay.co.uk/ws/eBayISAPI.dll?ViewUserPage&userid=atp-spareparts
Track rods and rear bushes last about 20k, which is quite reasonable considering both wishbones, both droplinks and both complete trackrods are usually £75-90 delivered :y
That said my last couple of sets were polybushed prior to fitting, and the current set has polys all round :-\
